sweetbeats
Reel deep thoughts...
This sucks...
Tim, I haven't digested your detailed post a few back yet, and Danny I haven't read the article yet in your last post yet, but (obviously) I have no ACG card and even if I did I'd be limited to 48kHz sample rate...the ACG card has a BNC wordclock out right? I'm using my Presonus Digimax FS as my wordclock master...it has the Presonus Jet PLL clock in it which sounded less smeary than than the clock in my Yamaha 01X so I set that as the clock master and then it feeds wordclock to the Yamaha i88x via Lightpipe. The i88x is the "soundcard" that Cubase sees. So anyway, the Digimax FS has a BNC wordclock connection on itbut I can't reall if that is out or in. If it was an input then I could take the ACG card clock output (if I had one) and connect that to the Digimax FS and keep on working the I have been working only I'd be limited to 48kHz, which would bother me.
I'LL POST SOME VIDEOS LATER OF WHAT IS GOING ON, but I'm sure it directly correlates to what Tim is talking about in his post (which I have yet to digest) but what I see happening is that when I solo the MIDI member of the group (the Cubase MTC output) and put the Cubase transport into PLAY, there is an error of about 50~90 subframes. As the transport plays that error slowly jitters its way down to 0 and as it approaches (jittering on and off of 0) the "L" flickers, the "I" flickers correspondingly on the upper right of the Micro Lynx LCD, and the relays clickity-click like mad as the Micro Lynx tries to lock to this "drive-by" timecode entity. As the error passes through 0 and rolls back to 90-ish subframes the clicking ceases and the lock indicators cease as well, but then it naturally happens again, cyclically. The timecode on the tape is whatever was striped with the Micro Lynx TCG set to the "29.97Hz/30" default (is that 29.97dfps???) and cubase MTC is set to output 29.97dfps, THOUGH IT DOESN'T SEEM TO MATTER WHAT FRAME RATE CUBASE IS SET TO BECAUSE THE PHENOMENON HAPPENS WITH EVERY ONE, THERE IS JUST A DIFFERENCE IN HOW LONG IT TAKES.
Again, I have some Quicktime videos I'll put up later today, but I'm severely disappointed and upset at this moment (not AT anybody, just at the situation) as it appears the Micro Lynx WILL NOT reliably slave my BR-20T to the DAW unless the house is sync'ed to wordclock from an ACG card and then I'm capped at 48kHz, and I'm not even sure that the ACG clock is as good as the clock in my Digimax FS.
I had exactly the same problems as you described. Clickety-click shuffle... Then I fooled around with the ACG but I disconnected it again, so I'm not using it, just as Danny pointed out. I didn't reset the configuration though and that's what makes all the difference (at least in my case). Press SETUP, MIDI, then a few times the NEXT button until you arrive at the MIDI Resolve option. Set it to ACG servo via the + button. Leave the configuration via SETUP.
It's time to have a good look at the results.
