So, 1kHz tone recorded on my
Tascam 238 has an audible "warble" in it when reproduced. Like pretty bad.
My prime suspect is the pinch roller...I cleaned it and it looks and feels nice, but upon closer inspection it looks like there might be a slight wobble to it.
What does this have to do with the M-__? I was going to record some more tone while watching the pinch roller closely to see if the rhythm of the warble corresponds visually to the pinch roller wobble. My handiest oscillator is part of the M-__. Of course the master section is all pulled apart right now trying to chase down the sputtering and popping in the master section...waiting for a new set of probes for my oscilloscope to arrive because my old 10X probes aren't proving sensitive enough for the HF noise I'm trying to see on the scope, so I can start tracing and hunting down the source. Anyway, it looks like this right now:
Anyway, as I'm carefully positioning the guts to make sure nothing is going to make fire when I power up the mixer to use the oscillator I notice a problem with my master fader...can you see it?
It appears the yellow wire has decided it doesn't like the fader anymore. I've had to deal with a healthy number of fragile wire joints on the M-__...didn't notice this one, until now of course.
So, okay, time to repair and improve. The joints should be reinforced by some heat shrink, and it's always bugged me one wire was yellow...it should be brown to go along with the standard color/number scheme; brown is 1, red is 2. Yellow is 4. Brown and red often represent left and right in audio gear guts too.
So I dig out spare connectors and wiring and find a good equivalent AWG donor set of wires of proper colors, desolder the old wires, remove the sockets from the plug housings, and prep for the replacements to be installed:
And...better.
And with that I believe the matter is repaired and improved, and I'm about 25 minutes closer to the afterlife.
Somebody please get me a job doing this stuff.
Now back to my 238 warble problem.
