I did some testing too...
I hooked up a condenser mic and some line signals carrying pink noise to test the gozintas and gozoutas of the channel strip...everything works, though I'm a little more confused about some of the routing...I'll get into that later...took a couple pages of notes. Pretty interesting stuff, to me anyway.
So the signal path for tone and noise generation was via a Windows-based PC:
Test Tone Generator software application -> Tascam US-224 LINE OUT -> M-___ LINE 1 input.
I measured 0.3V RMS at the LINE OUT cable from the US-224, and then measured 0.3V RMS at the PRE [fader] OUT of the channel strip for setting the TRIM knob, and then connected the DIRect OUT of the M-___ channel to the LINE IN of the US-224 and measured 0.3V RMS there as well for consistency. The input at the US-224 was then monitored with Roger Nichol's Inspector plugin to get the following screenshots.
Here is a 1kHz test tone at the LINE 1 input to DIRect OUT, EQ in and flat...not sure what the spikes are at 2k, 3k, 4k, etc...:
And here is pink noise through the same signal path. Not sure why it slopes up so much to the left, but it is passing audio, yah? I had the analyzer set to register average levels with slow response ballistic...you can see that it is pretty smooth at the high and low registers but does break up a bit in the middle. Pretty normal stuff I imagine:
Here's what happens when I insert the 12.5kHz LPF filter in the EQ section...looks like maybe a 12dB/octave slope? Hard to tell with this analyzer...The PE-40 LPF filter is 12dB/octave at 15kHz:
Here's what it looks like with the 160Hz HPF inserted...looks like 6dB/octave to me...this is the same as the PE-40:
And here's the 50Hz HPF inserted...I'd say that's 18dB/octave...same as the PE-40 except the PE-40 features an HPF at 60Hz and 18dB/octave vs. the 50Hz filter:
And here's a shot of the LINE 1 input with no source connected, TRIM knob and channel fader at maximum:
Here is a 0dB 1kHz tone at the MIC input:
Now here's something interesting...there was a question in a thread over in the DIY forum about whether or not a dirty TRIM pot can effect signal quality when it is not being turned...I believe this is evidence that supports my opinion that it
can...this is the same 1kHz tone through same signal path as the last screenshot...the pot is a bit scratchy; not terribly so, but would benefit from cleaning. I had to dicker with it to get the relatively clean screenshot above, and when I move the knob a little and then take my fingers offa it this is what it looks like:
And last but not least here is the MIC input sourced with no input source connected, TRIM and channel fader at maximum:
I have many more bits of info to put up and I'll get to it in the next while...
