sweetbeats
Reel deep thoughts...
Yeah it takes time using it to get used to what's where, and there are many aspects I'm still fuzzy on...all the SOLO points...the REMOTE functions to name a few. It's just easy to get physically lost in the former sea of beige, but also operationally lost particularly if there are multiple things muted on multiple channels, but certain busses are not effected by certain mutes...the functionality is good, it's just easy to go "wait...why am I/am I not hearing that there?", and then remember one of 60 mute controls found amidst the 12 channels is activated. With time it will become more familiar. I really haven't mixed any projects on it, just played around, and an actual project would force the acclimation.
To your earlier comment about the missing components, yeah...I tried following the traces to see if I could gather whether it's for input or output and at what point in the signal chain it interfaces...I'm pretty sure it is an output. The interesting thing is there is space and sites for another set of regulator transistors...on that same PCB is a regulator circuit for the +/-18V rails that power the +4dBu output circuitry. Usually that regulation happens centrally in the power supply...that's the way it is in the M-500 mixers but for some reason in the M-__ the power is rectified in the PSU and then runs unregulated at +/-35V and then regulated in each module...in the master section too...but there is room on the heatsink for another set of regulators which seems strange unless there was to be even higher power rails for the missing circuitry...there are some +8dBu circuits on the board too so maybe there was intended to be balanced +8dBu outputs for the PGM busses, which was the broadcast standard. Dunno. But fun and interesting to surmise.
