All good points.
The trick is that the M-__ could be very well utilized in
my studio bridging the analog and digital facets...
But more importantly at this stage I just want to *know* everything works, and in that process get a final handle on the specifics of each function...details that would be clear in a manual or block diagram, but obviously neither of those documents exist. Details like the solo functions for the stereo, monitor and PGM busses are in-place...and the master channel mute kills everything *except* the output at the direct out jack or signal dumped from the monitor buss to the stereo buss via the MONI TO STEREO function...and in the AUX buss switchracks the PRE/POST function only affects
the control if the pair of AUX busses are sourced to
the module input. If the pair is sourced to the monitor buss via the INPUT/MONI switch the PRE/POST switch is inactive...and furthermore if the LINE 2 switch is depressed (LINE 2 was intended for tape returns), that trumps both the PRE/POST *and* INPUT/MONI switches.
Stuff like that...I'm not looking to find ways to use every function, but expect much of the M-__'s functionality *could* be well utilized, so it's valuable to get into the weeds of what's what on this.
And in particular the REMOTE functions, which could really be helpful for global switching between DAW or tape playback, and global monitor switching. And actually the REMOTE functions can be used as mute groups!  There are two mute groups possible with
the REMOTE functionality.
I'm really thinking some video of the functions would be interesting and also helpful for me.
