Did some initial testing to get a baseline for the noise floor of the mixer last night. Also made some more progress with getting the knob and switch caps converted to the new color scheme. 9 of the 12 modules are completed...I'm still waiting on arrival of some additional parts to do the other three. Here it is with 8 of the modules installed:
I really like how it looks much better than either how it was when I originally took possession of it, or the first color scheme to which I changed it. I think this new one just makes more sense to my brain because it follows the same scheme as so many other Tascam mixers: red for inputs, orange for EQ and monitor buss, green for AUX busses, etc. Notice the knobs at the very top of the strip...the 5 on the left are red and the 3 on the right are green. Those are the "BUSS MASTER" pots. For modules installed in the first 8 slots of the frame those pots control the level sum of PGM groups 1-8 respectively. For modules installed in slots 9-12 those pots control the level sum of AUX busses 1-4 respectively. It doesn't matter what module is installed in any given slot...the function of that control is determined by the slot into which the module is installed. It would make sense for each module's color scheme to be identical to the next, but I wanted some visual differentiation to the scheme for those modules that I will normally install in slots 9-12, and to have those particular modules' BUSS MASTER pots be green instead of red since green is the color for the AUX busses and normally the AUX masters are green on other Tascam consoles. I am also using slightly different fader caps on modules 9-12...they have a white center stripe instead of orange as on modules 1-8...just another minor visual differentiation at the bottom of the module to compliment the one at the top. I could have done that to any of the 12 modules, but each module is hand labeled by number. It doesn't matter where they get installed, but simply because they are numbered 1-12 that's how I want to install them in the frame in that order. So the three right-most modules are module #s 10, 11 and 12. The 5 on the left are actually module #s 3, 4, 5, 6 and 7. I'm using those modules for my noise testing because they are unmodified. Modules 1 & 2 already have opamp upgrades as does module #8, and module #9 is currently partially disassembled because I'm studying it in order to draw up the schematic for the BUSS OUT level boost circuit. Anyway...more than you wanted to know.
So as far as the noise floor testing, there's more to do, but so far I've determined it's a relatively noisy mixer. Here's what I know so far as far as broadband noise measured using my Fluke 85 DMM:
Test conditions:
• 8 of 12 I/O modules installed
• 8 modules sourced to the MIC input
• 150R resistors strapped across pins 2 and 3 of the MIC jacks (to load the mic preamp)
• MIC trims at maximum
• EQ bypassed
• PAN controls set to center
• channel faders at unity
• stereo master fader at unity
• Fluke 85 DMM connected to STEREO R output jack and set to AC volts
Under the above conditions the DMM displays 0.4mV which is a signal to noise ratio of -58dBV.
If I set the PAN controls to hard R the DMM displays 0.6mV which is a -54dBV noise floor.
If I mute 7 of the 8 modules (PAN returned to center position) the DMM displays 0mV to 0.1mV...I'll call that -70dBV.
So, not so good. I've got some additional testing to do maybe this eve to narrow down if the noise starts up in the head amp or is further down in the signal path...or a combination. I dunno...it may just be a noisy mixer...there is quite a path signal has to traverse...to get to the channel fader signal from that mic jack goes through 4 different PCBs, goes through some relatively complex analog switching transistor arrays (because of the programmable global remote source switching features)...we'll see. My goal at this point is to try and nail down if it is noisy just because it's inerrant in the design but the design is technically correct, or if it is inerrant in the design because there is a design flaw, OR if there is some type of global failure.
