RecordingMaster
A Sarcastic Statement
This is how my room looks now, I have built 2 bass traps for the corners, I built a 2 frames, 15" against both walls and joined across then I wrapped the frames in sheet and filled with rockwool loft insulation, wat I did with the insulation was roll it out and cut it into triangles and stacked the triangles on top of each other in the trangular frame, then i mounted them in the corner of my room behind the monitors, I have 2 absorbtion panels on each side wall in the reflection points both 4" deep of rockwool loft insulation.
View attachment 72821View attachment 72822View attachment 72823View attachment 72824
Sounding any better?
If you have any open cell foam that is on the denser side, I'd suggest placing it under your monitors, since right now, they're just sitting on a wooden stand which is also on a wooden desk. So the sound from your speakers will vibrate right through the stand and the desk, coloring the sound. You could go the lazy way (instead of trying to find some foam free somewhere) and just buy these.
