pchorman
OK cute. First, for the record, a worn fret raises the pitch, not lowers it. A worn fret is wider, and a wider fret might as well be a narrow one that's slightly higher up on the neck.
I don't argue with anything Tom said earlier, but it just doesn't explain all the intonation differences which exist. That analogy with columns of air doesn't apply, so if you can come at me from a different direction I'm all ears. Also, your string mass statement has a minor problem which kept me from following. You stated, "When you touch your finger lightly to a string to produce a harmonic, you have halved the distance but NOT THE MASS. The string "senses" this excess mass.."
Wait a minute; I think you implied that the mass didn't change so what is this excess mass you're referring to? The finger? Help me out here.
There is at least one nut mfr and another fret mfr which attempts to compensate for the hoaky g-string problem. I will have to go back to the old post and dig this out.
Also for the record, and I don't want anyone to take offense, I believe we should be saying "intoned". Saying "intonated" is as bad as saying "orientated". NG!
