B
burok
Allrite then, I'll try it out as soon as I get some power-supplier.
and yeah, the midi stuff is no problem, it's just that I'm totally lost when it comes to analog recording.
I'm a bit confused on this with loading the tape etc, because if I load the tape - it plays the tape forward etc, I reset the time-stamp so it knows where the "loaded" start point is. but if I turn off the machine, I'll have to load again (right?), and then it won't go from the position I had the last time. Instead it does the same procedure as last time and I just get longer and longer into the tape. Which is the right procedure with this? Everything concerning the tape-handeling is a bit blurry for me, and I can't say the manual helped me on this (or I've missed it). And if storing more than one track on each tape, how do I do that I a correct manner?
and finally: if I've made a couple of tracks on a tape, and then remove it - and after a while, I want to check out the track I made - I put the tape back and load, will it really find the same load-start point as last time...?
I guess you're all laughing now, but hey
