B
burok
I'm off on sunday to get an tascam 388'a, I've made up my choice and left the computer way around it after too much hazzles with soundcards etc etc.
Though, I'm a total newbie to analog recording so I'm wondering the following:
1. what should I check for when I go there on sunday to check it?
I'm not aware how tape heads should look if they're in good condition
and I'm not even aware of how they look like, and where they are on the 388.
something else that should be checked for except for noise sliders/pots and such?
2. how do I maintain the 388'a in a proper way?
guess: using good tape, cleaning the tape heads and demagnitize ?
a. where do I find good tape and which types should I use? (I know it's supposed to be 1/4"... but that's pretty much all I know) preferably in europe. I heard of tapetape.com ... but that's in the states...
b. cleaning the tape heads, how? using isopropanyl (or whatever it's called)
c. I'm getting a demagnitzer with the 388, how do I use it?
how often should I use it, and what can happen if I don't? (it sounds like it could be dangerous. (it's some TEAC demagnitizer btw.)
3.
how do I know which level the machine is tuned for? I heard that you can set the db level to different settings such as +5db or +9db which also affects which type of tape you should use?
3.
