Studio build in unfinished "bonus room" above garage
  • Thread starter Thread starter robn
Looking good Robn
This is my first post in probably about 3 years too, Robn. Your build looks like it will turn out real nice. I just wanted to tell you that I'm going to be watching this thread to see how you do things and how it turns out. I've got a 26' X 24' detached workshop that I plan on converting into a small studio space. It looks very similar to what you are building out. I do have a question about your insulation in the roof area: Did you insert those plastic spacers they make now to provide an airspace between the decking and the insulation? I'm curious about that because I've heard that you don't want the insulation directly against the decking and I just found out about the plastic spacer panels a few weeks ago.
At this point I'm thinking that I'm going to look at a mini split HVAC system since I don't have any AC/Heat downstairs OR upstairs. I understand they are quiet and easy to install. That way I don't have to deal with ducting. Of course all this is just dreaming and scheming right now. I have to find some funds to work with as well.
Good Luck with your project.
Mike
Well, welcome back Mike!!!!!
I'm jealous of your studio build then, you've got alot more real estate than I do!!! No, no spacers....I wasn't aware of them......my insulation has backing on it, but I didn't know it would cause any problems.....what problems is it supposed to cause?
A mini-split HVAC sounds good.....seems like it would be less hassle.....I hear ya about financing, I started this project about 3 years ago, then ran out of money......took out a small loan of $2600 to finish up, and I wish I'd taken at least $5000!!!! Seems like it always costs twice as much as you think it will !!!
Good luck to you, be sure to post on here when you get started.....lots of good folks on here to help you out......Rick Fitzpatrick has been alot of help to me (and others) and there are plenty of resources here.
Looking forward to seeing YOUR build
Yeah, I'll TRY to be patient.....anything I can do in the meantime that won't mess things up, like starting on the west side knee-wall? BTW, I'm really really curious to know why you don't recommend RC.......
Yes. Quite as few really. Under normal circumstances, I would recommend it.
However, your situation is governed by your floor membrane plane and simple.( was that a pun?...hahahahaha)
And I'm sorry I suggested the use of it in earlier replys. Hindsight is 20/20, and after further analysis of your situation, it appears my earlier advice is not aligned with the facts of your situation. Although RC certainly may help, at this point I have to consider some additional information you have provided.
Namely, you are not recording live drums nor bass, nor lMarshall amps on 10, or a full band. This situation would require every technique available, not to mention tons of mass AND money.;)
Understand my view is coming from simple intuition, common sense, and my belly.:D However, I will explain.
1. Simple physics(I don't claim to understand physics on a academic level)dictates that LF resonance or even plain sound waves will vibrate your floor as it is a membrane. Especially at certain frequencies. Under normal circumstances, given a studio with a SLAB as a floor plane, sound has little effect on the mass, as it is DAMPED by the earth. Although, structural transmission can occur as a result of impact, simple airborn sound has little effect on concrete slab floors, and what effect it DOES have is simply negated by decoupling the slab from the foundation footing which the building envelope rests on. In that situation, the use of drywall decoupling makes all the sense in the world.
. Your situation allows no such mass, let alone damping, let alone total decoupling. That is why I suggested the use of the KIP flooring as a partial solution, although I am absolutely sure, resonance can induce transmission to the building envelope regardless of a "decoupled
So, in essence what you have is a membrane which is structurally connected to the surrounding envelope. No amount of decoupling of the wall/roof envelope from the structural support will keep the floor membrane from vibrating at certain frequencies, as the entire envelope will resonate at certain frequencies, because there is not enough MASS in one plane to decouple the rest from....ie..a SLAB.:(
2. Practical elements of actually implementing RC with your building envelope
conditions....ie...sloped walls, angles, and multiple layers of drywall. RC is easy to mount on the framing under normal circumstances, and with a modicum of pre planing, storyboards, and common sense, even a layman may successfully fasten one layer of drywall when the room envelope is a normal box. However, the next layer becomes exponentially difficult to fasten as now the RC is hidden. Even with EXACT layout lines, the possibility exists for ONE screw to COUPLE the drywall with the external framing, which if were to happen at a critical connection may undermine the whole ball of wax.:eek:
Now add the following elements and it will become blindingly obvious why installing RC in a studio such as yours would require the UTMOST in preplaning EVERY SINGLE DETAIL. I believe even Rod would agree that when RC is dictated by a designer, NOTHING is left to chance, and the tradesman are under CONSTANT supervision to assure complete success. Even under nomal circumstance, the chances are great that the RC is compromised, even partially. I have read tests of an RC installation that was DE-constructed whereby PROFESSIONAL installers made numerous errors, although the installation was not totally compromised. Something about how many drywall screws connected with the framing.
a. Details at the door jambs
b. Decoupling of HVAC duct regesters/grills(you've nowpenetrated a decoupled interior envelope that you've tried so hard to install correctly. Now you connect a duct regester that is tied to a structural element above.:eek:....ie...decoupling the register from the strutural element as well as the drywall)
c. There is no sense in decoupling the drywall and leave the floor membrane UN decoupled via a roll out/tile product with integeral vibration decouplers. Therefore, IF RC is to be installed, a DECOUPLED floor product must be part of the overall package.
Now, the detail at the drywall, decoupled floor must be addressed, as well as the installation sequence/ baseboard decoupling/ and DOOR threshold seal details too.
Now add these little nuggets to the problem at hand.
1. Your sloped walls...you now have hanging mass that is NOT depending on SHEAR of the drywall screws for seperation from the RC, but depending on the NON PENETRATION of screws through the drywall membrane sheet. Which under PRO use of the correct drywall screw fastening tools is probably not a problem. However, DIY use of a common drill may preclude success, as even I, being as carefull as possible have routinely driven screws though the facing sheet of drywall, although it hardly mattered given the project at hand, AND there were a thousand other screws providing SHEAR protection.:D I know this seems rediculous...but consider the drywall is now HANGING at an angle. Not only that, but given the added mass of a second layer, you now must consider this weight PULLING the RC flange OUTWARD. Maybe this is a problem, maybe not. I personally have never delt with it but in MY mind...I AM a long time aquaintance of MURPHY!:D:D Needless to say...I am apprehensive.
2. Angles. Consider this. At the west wall roof plane, fastening RC to the roof framing 2" above the floor will be an excercise in fastening frustration. To drive a screw in perpendicular to the roof plane would be IMPOSSIBLE, unless you had a RIGHT ANGLE DRILL.:eek:
And then you have the angle at the web frame cieling plane/roof wall intersections. Under normal wall/ceiling drywall intersection conditions, this joint can be offset by an 1/8" or so as the connection is at a right angle, and can be easily caulked, and the next layer installation sequence will cover this gap and will allow ANOTHER 1/8" gap to be caulked. HOWEVER, with angles such as yours, butt joint gaps will be a totally different configuartion, requiring very accurate drywall cuts, which knowing how common carpenter framing is, may be easier said than done, as the ceiling PLANE framing may NOT be perfectly IN LINE. Should this be the case, this would require custom cutting of each piece, if in fact custom SCRIBING each peice as one can imagine not only is the ceiling drywall HANGING on RC, but because of small inconsistancys in the framing PLANE, the WIDTH of this ceiling panel now will be slightly CURVED at some points, as these inconsistancys in the plane may cause not only the RC to BEND to compensate for the non flatness of the ceiling plane, which in turn requires the drywall panel to BEND when fastened to the RC. :rolleyes: NOW, when the roof drywall is DIMENSIONED for cutting, the edge of the ceiling plane is NOT a straight line. It bends up and down like a scribbled line.
This may be a worst case scenario, but SHIT HAPPENS, and dealing with it down the road, especially when it comes to trying to screw dryall, to a 1/2" RC flange, while maintaining a 1/8" gap at NOT ONLY, the ceiling, but at the KNEEWALL intersection as well. TALK ABOUT A FUCKING NIGHTMARE!!:eek::eek: And thats just the first layer...geezus...how do you spell....hmmmm....did I mention TONS OF CAULK for NON LINEAR GAPS!! Not to mention curved joints when it comes time to TAPE and MUD!!
Murphy would dictate that when installing the RC on the ceiling web frames, I would HIGHLY recommend stretching a string across the complete length of the room, up against these framing webs, prior to actally installing the RC. And THEN, if inconsistancys require it, to SHIM the RC to achieve a FLAT PLANE. Even then, small width inconsistancys may STILL require custom trimming of each piece of ROOF WALL drywall. IN FACT, if it were me, I would probably use a utility knife or sanding block, to manipulate the edges of both the ceiling dryall AND the roof wall drywall into a OVERLAP MITER.:eek::D This would insure no gaps whatsoever. The roof drywall would actually overlap the ceiling AND kneewall drywall in such a way where there would BE NO GAP. Remember, airtightness is part of the overall TL strategy. Should you opt fo simple butt joints allong the kneewall/ceiling intersections, given TWO layer buttjoints, his situation alone could be a gap CAULkING nightmare.
Ok, NOW, consider where these kneewall, ceiling and roof plane drywall panels meet at your NORTH wall. Now you have another situation Think about it. Not to mention, should you decide to use MY rear wall design solution for a symetric rear wall, now you would have COMPOUND ANGLE intersections....consider the angled portion of the rearwall where it meets the roof...:eek::eek::eek: hmmmmm, custom cardboard TEMPLATE layouts come to mind.
Ok Robn, I have a situation at home I have to take care of immedietly(father in law health problem), so I have to leave now. I'll be back with a ton of illustrations and other opinions. Later(sorry I couldn't finish at the moment but I believe you get my drift here.
PS. Solution. Two layers of 5/8" drywall fastened DIRECTLY. Mass is my suggestion. Same at floor. btw, blocking at these intersections will allow for easier fitting and fastening. AND a kneewall at the west roof.
I'm back from the hospital.:rolleyes:My father in law, bless his pee picking heart...is a FUCKING IDIOT!!:mad: Pulled his catheter out in the middle of the night..ripping a blood vessel, filling his bladder full of blood..and miscel other things...all because of his damn stubborness..and thinks he KNOWS his own body and can make what ever decisions for himself what EVERY it causes to himself and other people. Damn him sometimes. Now my wife has to stay at the hospital all day cause hes going into surgery immedietly. Now I don't have help finishing the days painting. :mad: Sometimes....sometimes...I want to SCREAM!!:rolleyes:
Excuse my venting Robn. Ok, let me say this. PLEASE don't start building that knee wall yet. I need to talk to you and show you some things. But I don't have time at the moment. Just tell me whether or not you are CONSIDERING that rear wall design. Gotta go now.
fitZ
btw. its 53 degrees right now.:D Curses.:p
fitZ
Great thread. Exciting stuff, guys.
Yea, it sure is cause this COULD be a killer little studio. It all has to do with holding those reins tight.:D How ya doin Casey? Enjoying that 106+ weather?:p
Rick,
Your F-I-L sounds like my old departed Aunt Bonnie, God rest her soul.....she was always thinking she knew more than the doctor and did what she damn well pleased.....I think sometimes she did it just for the attention.
And back to the studio.......yes, I'm definitely interested in your south back wall solution......but I'm having a hard time with the second drywall concept in general....with or without RC.......the RC is 2 1/4" X 1/2", the 1/2" is how far it sticks out from the studs......I don't understand how it's going to be any harder hitting the 2 1/4" RC than the 1 3/4" stud? How do you know where either of them are when doing the second layer unless you mark a line on the 1st layer drywall......I must be missing something there......
BUT you'll be glad (and surprised) to know that I haven't proceeded with ANYTHING lately (except the 1 HVAC baffle box). Haven't heard back from the HVAC guy but I don't think what he would do (which is fasten the supply and return to the ceiling studs and tie-in with the return with my baffle box inline) would affect anything right now anyway, although he will want to know how far to drop from the ceiling.
But yeah, I'm onboard with the back wall thing......keep it coming.
53 degrees? It's a mild 88 here.:mad:
Supercreep,
Hey anytime you want to chime in with some advice, feel free.
:eek::eek::eek: What the fu....was I thinking. Its been a long time since I looked at mine. I have a shit load I bought over ten years ago and haven't looked at it since...DOH!!:o:o I can sure be a moron sometimes....well, lets see then...uh....nevermind.:D:o:D
:cool: I'll be back as soon as I can. Gotta go work now.:rolleyes:arrrrgggggggggrrrrrrrrr...I hate this mobile home project. Comin along just fine though. In fact....it looks GRRRRRRRRRRREAT!!:D EXCEPT...the other day I did the f...Kn cabinet doors. I SHOULD have sprayed an enamel over the oil based primer...but nooooooooooooooo. My wife convinced me to use LATEX!:rolleyes: I made a few racks for spraying them all at once outside. I let them sit there all day drying untill late at night. And THEN, my wife got all agitated that the fog might "ruin" them, and badgered me to bring them in. Well, I know from experience that you CAN"t STACK freshly painted latex doors, so I lined them up in the utility room. Next day, to my supprise, the wife and son MOVED them all to the shop so they could install a new washer and dryer(to suprise me:rolleyes:) ....well, yea, I got a surprise alright. STACKS of doors STUCK TOGEATHER!!!!:eek::eek::mad::mad: FUUUUUUUUUUUUUUUUUUUUUUUUUUUCK!! When we pulled them apart, they actually pulled pieces of the partical board off the fronts and backs where the paint was the thickest. Now I have to RE-SAND, RE PRIME...and fucking RE_PAINT THESE MOFO's!! I'm so mad I could kill. They were beautiful, even for latex. (sigh):(:(:(:(
Next day, to my supprise, the wife and son MOVED them all to the shop so they could install a new washer and dryer(to suprise me) ....well, yea, I got a surprise alright.
Sometimes ya gotta look hard at the motivation and NOT the end result :D
Hey Robn! Sorry I havn't been back here for a few days, but I HAVE been working on this. Got a few "interior design" ideas to toss your way. Hey, got any color schemes or design ideas saved away? Mostly, I've been working on the different drywall "shemes" to find out the problems, joinery, joints, disadvantages, advantages etc to each. I'm almost done so hang in there. I should have enough of this done to give you the info to make intellegent choices and decisions in regards to the rear wall, drywall, flooring etc.
There is something I've been meaning to talk to you about though. It has to do with the actual absorption product. In my opinion, I'd suggest putting a good chunk of your budget aside for some 4" thick, 4'x10' panels of Knauf rigid fiberglass. You won't be sorry. I'll be back tonight to explain. In the meantime, heres a few shots of some stuff just to tickle your creative juices.
One little sidenote here. These design concepts are drawn at the bare stud planes, as no decision has been made on a drywall scheme. Once you have your drywall/floor decisions made, and you decide exactly what you are going to do "treatment" wise, THEN is the time to look at all the framing/blocking required to fasten anything that needs it. Also, these "treatments" are based on two products. One, is 2" and 4" thick Knauf or 703, the other is Ultratouch. Also, these designs are purely "conceptual". IF, you are interested in one or more of these ideas, let me know, and THEN I can configure the actual dimensions according to the drywall scheme, AND HOW TO BUILD THEM.
Also, these are by no means complete. They're just concepts, and theres LOTS more on the drywall/floor detailing to post. Soon.
fitZ
is.php
is.php
is.php
is.php
is.php
is.php
is.php
is.php
is.php
is.php
is.php
is.php
is.php
is.php
is.php
Hey bro, good to hear from you, thought maybe you were trapped under a pile of 46 wood cabinet doors or something ;)
How's the Project From Hell? And your father-in-law?
I called the HVAC guy and canceled him......the city lets you draw your own permit for HVAC as long as you're the homestead owner, and since almost half the work is already done (supply side is basically done), all I need to do is tie into the return plenum, put my baffle box inline, and run the return into the studio......he was going to charge $300 and I can do it for cheaper than that.... on a tight budget you know :mad:
I had a guy come out from Harris Acoustics (local) the other day to give a second opinion on this project.....he told me they had about 15 acoustic panels left over from a job they finished awhile back.....it was for our Civic Center Auditorium....they have concerts there.......he said he could sell them to me for about $200.....don't have any more info from him....left a message for him at his office today but didn't hear back.....when I find out I'll let you know and you can tell me whether it's something I could use and at a good price.....
Right now I'm still thinking 2 layers of 1/2" on RC with Green Glue in between......that's my thinking right now.....
Haven't done anything lately though.....trying to be patient you know :o
no problem as long as he can tell you what they're made of. Guessing for $200 is as bad as going to the Casino.:D
Ok, I'll have the details done for the RC option by tomorrow night. Then you will see all the possible problems. Even fastening direct will be a chore, as all the angles create some bizarre edge conditions. Think compound miters at the edges not to mention the framing. Hows your compound miter skills.:D You'll see.
You won't have to be patient much longer. I'll have this whole thing in a format that you can make decisions on by the end of next weekend. At least the basic decisions. Theres always tons of on the spot decisions to be made too. But maybe having the options to look at might help you visualize the variables that will allow you to maximise you skills, materials and budget.:)
btw, what was that you said about a attic access entry? Something about size? I just assumed there was a stairway up to the second floor. What is the largest size panel you can get up there?:confused:
But not as much fun......
I was probably talking about the hole into the attic that I would need to be able to fit my baffle box thru......yeah, there's stairs.......I think I understand where your confusion lies.....the "attic" is not really on the 2nd floor.....we have a 30' ceiling in the living room, and the "attic" is above that......on the same level as the HVAC I took pictures of, just a little further east.......the attic access "panel" is in the hallway on the second floor......the HVAC unit for the first floor is on the same level as the studio, the HVAC unit for the 2nd floor is 1 level above, in the "attic"
From the living room on the first floor:
This is leading up to the studio.....the ladder is underneath the panel into the attic:
This is from the 2nd floor hallway...you can't see one of the bedrooms, but the door on the left is the bedroom that borders my south studio wall....the door to the right leads into the area where the studio is.....after you go thru that door, immediately to the left is the studio where the entrance will be....
Hope that helps.....catch ya later!!!
I guess so. But I never thought gambling was fun...maybe because I could never afford to loose money.:D
Ok, NOW it's clear as day!!! Almost.:D All I need is a couple of more tidbits of info to put the puzzle together.
Robn, looking directly at your rear wall, from inside the studio, there is another wall right behind it. Is that wall in the same plane as the wall with the hall door to your studio? (I assume it is). I also assume this wall is the north wall of the adjacent room with the dormer, as I see insulation in that wall, and it must meet the west dormer wall, with the window in it, no? At least thats what I've extrapolated from the pictures. All along, I thought the "bedroom" was this adjacent room to the studio. Now I see it isn't, but what IS this room with the dormer for?
And one other thing You built a wall parallel with this dormer room northwall. I can't see in the pictures, but it appears you terminated this new wall at a point where you plan on framing a wall for the actual studio door, no? If so, that would explain a lot of things. Can you take a pic of that wall termination and the gap between the new wall and the hall door wall? Thanks
Yes it is....the hall doorway is on the same plane as the closet in the bedroom....if you are looking at the south wall in the studio, you are looking at the back of the closet....the area to the right (looking at the south wall from inside the studio) is the back of the bedroom wall.....
The dormer is a fake dormer......there is no bedroom behind it......and it is well east of the bedroom and studio.....
A few more pics to hopefully clarify the house layout....
Looking south:
Looking southeast:
A closer look at the south studio wall / back of bedroom closet/wall:
This is a look at the back of the house.....from the backyard and looking northeast:
Looking straight north from the upstairs hallway, looking into the studio area:
A modified pic you've already looked at:
Hope this helps
Hi Robn. I'm a little confused. Isn't the bedroom closet opening wall inline with this north dormer wall or something close? And is this the dormer that is fake or is this a real dormer which is part of the bedroom?
That one is part of the bedroom, the bedroom that borders the studio....
Here's the pic:
The fake dormer really doesn't factor into any of this.....
A front view.....see the arrow with no text? Behind that roofline is the passageway that leads to the water heater and into the studio if you kept going west......
The fake dormer has no back opening......the back of it is the roof
Here's you a birdseye view:
Hasn't got a thing to do with the studio, but the birdseye view just looks weird to me now.....this is what that left side (southeast) corner of the yard looks like now:
(Taken from the back bedroom 2nd floor window during a rain/storm)........that was about a month ago......it's got more shrubs, bamboo trees, statues now.......my Spring/Summer Project
Hi again Robn. That has got to be the wierdest roof I've ever seen.:D I bet the guy who framed that had nightmares.:p Anyway, thanks. NOW, I know whats happening, although most of it doesn't have anything to do with this. I was just curious. Ok, well back to work on this. One thing these pics did do was help me eliminate one idea I had. I won't go there though. Not worth the time. I'll be back as soon as I can with the rest of my suggestions.
As to my project from hell..:D, another week and I should be able to wrap it up...thank god. I'm sick of it. :rolleyes::p Can't wait to get back to my own studio project. One aspect of this project I've been working on, is I was able to score a compound miter saw, which I need to finish the framing for the ceiling/wall superchunk fabric frames. They die into my soffits, and this creates some angles from hell. Fortunately, Sketchup makes it easy to measure these and translate to the saw. Just laying the frames out in Sketchup took a couple of weeks. Another aspect was having access to a pocket boring machine. Made these easy to design and assemble. Without it, I would have had a lot of trouble with joinery. Heres what one looks like. I'm still waiting to finish the end that dies into my soffits. Take a look.
And DON"T laugh at me too much. I know I'm an old fart.:D
is.php
is.php
Heres what its supposed to look like when finished...IF I ever get that far before I kick. Ha!:rolleyes::p
is.php
is.php
and one for the fantacy collection. My "ice cream cone" diffuser.:D
is.php
