			bouldersoundguy
Yep. Note that the wall may be producing boundary effect, a low frequency boost caused by the speaker being close to a reflective surface. The switch on the back labeled "Room Compensation" counteracts the effect.
			I wondered if that might be a possibility, even though the wall was at 45 degrees to the speaker faces, and underneath the speaker. Maybe draping a load of blankets over the wall, under the speaker would be worthwhile. Thanks also for your earlier suggestion re isolation, and trying the measurement with mic pointing at the tweeter.Yep. Note that the wall may be producing boundary effect, a low frequency boost caused by the speaker being close to a reflective surface. The switch on the back labeled "Room Compensation" counteracts the effect.
			Thanks, Rob. Two of the curves are acceptable to me. The green one isn't, but I think I can rectify that. I don't think I'm over-thinking anything. Okay, I may have geekish tendencies! My reason for wanting to do these speaker tests was to determine how accurate the speakers are, while still within the time window for returning them, if necessary.You now have three perfectly sensible traces. I do think you are over thinking the entire thing, losing perspective. If you turn down the blue speaker a tiny bit it tracks perfectly, the green trace suggests the HF unit has a difference in HF response. Its a gradual tapering off, then a sudden spike. Being blunt, you are seeing things you cannot hear. I’d bet that that big spike at the end you cannot hear. When you listen to music on them that you know well, what do they sound like? The bass end starts to tail off, like all small speaker designs at the bottom. Hear it is 100Hz where it starts. If you want to mix music with lots at the bottom, then you have to guess the level of bass in your mix. I must be careful in my video studio. I often mix there and when i go home, i hear too much bass. My car hears too much bass on the journey home. Depending on the type of bass, as in synth bass, piano bass, double bass bass orchestral bass, or electric bass, i can pretty well adjust my choice, and get it mostly right, but bass at my audio studio is more accurate somehow - probably just bigger drivers and older design I guess.
Nothing you have, bar that measurement mic has a flat frequency response. Flat is boring. As you have discovered, small differences in your test produced very different and alarming results. Ask yourself the question ‘did the speakers sound as bad as the results, or was it a shock?’ Those little peaks and troughs did not alarm you. You didn’t think my god I've lost 30dB of level, or i have a huge peak at X or a total lack of signal at Y. Your ears and brain told you a sort of compensated result. The flawed tests have surely proven that none of your worries are the speakers. You can compensate. Forget trying to EQ it out. If you remove a tiny peak at 4.23KHz by taking 2.6dB out, can you hear it? Of course not, but flat line chasing is pointless.
1. Do you like the sound?
2. Do your mixes sound good on as many systems as you have access to?
If it is yes to both, move on. If it is no, borrow a new set and repeat.
Forget what your eyes tell you. All it has done is produce predetermination. You see a fault, and are fixing something probably that is just ‘character’. I have listened to a tape of the Beatles at Abbey Rd, on the studio speakers and original amp they used in the early 70s. It sounded absolutely terrible. Tinny, weedy, lacking every quality word we now take for granted. They would fail your test spectacularly.
 Flat may sound boring to the average hi-fi consumer, but for me, when mixing and mastering, I want as flat as I can comfortably afford, provided the bass extension and clarity is adequate for me (which, in the case of these speakers, it is).
			I know what you mean. You surely have more experience than I do, so I respect your approach, if it works for you. I'm fully prepared for the horror show when I get the speakers in place and do more tests. It will be very revealing to compare the test curves from outdoors to the test curves done in the studio. It might even persuade me to move the studio to a better room. But probably, not, as they seemed fine when I tested them in the studio (apart from that treble deficiency I noticed). It remains to be seen how well my mixes translate, when I start mixing with them.If you want to scare yourself, repeat the tests in different places in the room.
I think I learned that (from doing this in theatres) interpretation is key - on it's own testing frequency response means very little. Pretty much now at a new venue I just play a track I know and listen. Very rarely do I need to dig out he measurement mic - most times I just think, bottoms a bit weak, or top is a bit harsh - and just do some basic output EQ. Chasing dBs on a screen showing horror stories I can usually live without.
			So you are saying that you judge a room your in and decide on the mix? Hoe Novel.....Actually, I find the venue sound far more tricky because often I am trying to create tracks that will get played there, so I've got a wider need to make sure the studio sound, works live, where the volume is up, the bass goes lower, but the acoustics wrecks the music more. Next time you record some acoustic guitar - try that measurement mic. you will find it totally soul-less, yet, it is flat?
Back in the analogue days we would have a 32 band EQ for left and a separate one for right, and you would squirt in the pink noise and produce a curve. The curve for left and right would be different, in a venue with symetry down the middle - but walls one side could be cavity and lightweight but the other side solid external ones. Many venues look symetrical, but are actually not, and some (like Plymouth in the UK) have a stalls and circle one side, but on the other, stalls flow into the balcony - very lop sided. Sound differences between left and right were often huge. Gradually, you realise that in a nice sounding room, weird curves can be quite nice sounding, yet in a different venue the weird curve is horrible. The acoustical clever folk do their analysis and frequency mangling and very often you listen and say surely not? Some venues like the Royal Albert Hall, where they do pop. rock, classics, choirs and speech is a very tricky acoustic to handle for some users. Some venues have acoustics so bad that an artist stands on stage and says at the soundcheck, can you put the PA on, when it is on. They take a pace 3 ft to their left or right, and they hear it, but that one place they put the mic stand is an acoustic black hole.
In studios, it's rare to find any truly awful ones. The commonist 'feature' is what people say is 'boxy' - from all those parallel surfaces. We get people who cover every surface with thin foam, that sucks the life out of the 10K and above make the sound very odd, but these often look OK on a response curve. My way of working now in the studio spaces I create is simply to play a track I really know well. I actually use Money for Nothing - the old Dire Straits CD - my first and favourite CD when CD was a new thing. The other is Tales of Mystery and Imagination. Those two do all I need. Instantly with the Dire Straits, you hear the fight with kick and snare, if your bass response is shaky - the spectrum is full of quite separate easy to identify stuff. If the track sounds right, no need to go any further. In my audio studio, the monitor levels are never adjusted, the output has no EQ whatsoever. I used to use the control room in Cubase, but it was too easy to change the level and not notice - and very rarely do I put any real effort into levels - I know what is loud and what is too quiet. rarely do I end up out of spec. It takes time to get used to new speakers and a new room. You get there eventually.
			That’s what I said even though it sounded Like I didn’t.No, the opposite = hear the room, make the adjustments -
12K? What 12,000 watt of power? What are 12Ks?- but I'm often mixing for a system with 12K's worth of amp power, so it has to be considered. Most times I get it nearly right. Thinking about this, it could also be why I am very sparing with compression, because I want the extended dynamics?
