stepXinXtheXmix
did you make that diffuser panel with all of the woodblocks? how'd you do it?
yeah I started by making a 2' by 3' INSIDE DEMINSION frame from 1 x 4 pine(.75"x3.5") then cut some 4' pieces of 2x2's(1.5" x 1.5") into random sized pieces, ranging from 1'' to 4'' pieces. i then cut some 1/8" plywood to 2' X 3' for a backing to crew the wood blocks to. I took some scrap pieces of 3/4" and made a "ledge" around the frame for the plywood to rest on and add some support and started laying blocks in the frame....
A problem I ran into that explains the gapped places is the blockes were not exactly 1.5" by 1.5" they may have been a 16th bigger so over a distance the 16th's added up and didn't fit exactly so i just split the difference of the gap and made it symmetrical.
other info...I pilot holed every block, if i didn't they would split. So there ya go...
