* Power supply arrived today from out of state...report is that the box looked undamaged, and I talked to the shipper about how it was packed (professionally packed) so it should be intact. Alas the umbilical is MIA...since the connector on the back of the console had a bunch of bent pins I'm wondering if the umbilical didn't get damaged...anyway, I followed up with Tascam and ordered the cable ends, BUT...one of them, the plug or the socket, is back-ordered. Not a big deal EXCEPT that it may mean its out of production.
The parts rep is doing me a favor...they're going to send a message to the factory in Japan and request an ETA on the part. That will avoid having to wait for the back-order to be generated...they're going to call me when they know. Here's hopin'.
* straightened the pins on the power connector on the console. I'm going to trace the pins to make sure nothing was damaged.
* I've cleaned the innards of the console out. Its still naked on the work-bench, but it is relatively dust-free. Haven't exercised any pots or switches. I'm planning on waiting until I connect power and run signal tests to know what is needed, and I'll leave the console stripped until I know what needs replacing.
* Speaking of replacing, in addition to the nearly complete 4-channel input block shown above, I scored another input block AND an entire master section for $69 plus shipping. This gives me replacement parts galore for the future. This latest set of parts does not include any knob, switch or fader caps, but all the rest is there including the nicer ALPS faders...12 of them. I'm pretty well setup anyway with knob/switch/fader caps anyway between the last input block and Herm I've got everything plus extras.
* Talked to Tascam enginering about the power umbilical cable stock...unshielded multi-conductor power cable...likely 20ga. Talked about it like it was standard fare. Not sure where to get it, but I haven't started looking yet either.
* Next steps? Test power socket pin integrity on the console; test the power supply; assuming the power supply is okay set the power supply right behind the console and unscrew the socket on the back of the PS and, using the slack in the line (hopefully) direct-connect the PS to the console, cross my fingers and push the big orange button.
