sweetbeats
Reel deep thoughts...
Well, I assembled an umbilical for the power supply. I must say it was a challenging process. The 22AWG cable was very nearly too big to fit through the solder eyelets...plus it is relatively stiff cable. Hemostats were a must.
Got a sort of slide show of the project:
Here are the materials I used to make the cable.
Here is the map I made up of pin assignments for the cable.
The first step was to put a piece of heat-shrink on the end of the cable. For the right-ange connector, the one that will interface with the back of the mixer, I stripped the cable jacket back 1.75", and applied a 1.5" piece of heat-shrink. I left 1.5" of the individual conductors exposed. I like using the 3:1 for this kind of stuff with the glue inside...
Here is what the inside of the hood looks like...
The first wire...
The first wire complete with little heat-shrink boot...1 down, 19 to go.
Here is a shot about halfway through...
All wires soldered! Time to stuff that hood.
Shot of the hood stuffed and ready for the other half of the hood cover.
Finished right-angle cable end:
This was a terrible thing...I was nearly done with the other end and my flush cutters nicked one of the cables...hench where the solderless connector came in...
Ahhhhhh...the finished product, and fully tested.
The first wire...
