F
frnkfrkl
Member
OK, I'll have to find those. Any particular pin for reference to ground or will chassis ground do the trick? Perhaps that will become clearer once I actually locate them.You’ve got your hands full and I’m not sure if I’m going to be able to help. Again if it is global then it has to be something high up in the chain. I would verify power is actually getting to the opamps…like check for DC volts at pin 4 or pin 8 of any of the 4558 or 4559 opamps. The other though is a faulty power mute circuit but I don’t know how the one in the 34B works. If I have time I might see if there is a description of the circuit in the manual.
Ok, are we looking at J102 or J106? There are 4558 and 4559 op amps on the rec/play amp PCB but, if I'm not mistaken, there are 4 of those, one for each channel, and they would all have to have failed at the same time. Shouldn't I be looking more at the MONITOR AMP PCB? Like maybe J203?You’ve got your hands full and I’m not sure if I’m going to be able to help. Again if it is global then it has to be something high up in the chain. I would verify power is actually getting to the opamps…like check for DC volts at pin 4 or pin 8 of any of the 4558 or 4559 opamps. The other though is a faulty power mute circuit but I don’t know how the one in the 34B works. If I have time I might see if there is a description of the circuit in the manual.
