Tascam 34 - meters doing strange things
  • Thread starter Thread starter rob aylestone
Well yes some models are built to 'mid price' levels and servicing almost anything is a trial these days (there orta be a law!) but as I say, Blackstar have a vast range up to the all valve Artisans, totally classic turret board construction and chunky transformers. Not cheap but nowhere near the price of your 'Booteek hand wired' amps.
It is indeed a 'hybrid' amp but all the "tone" comes from valves in the HT-5 and I defy you to find a more versatile 'studio' combo? 5 watts clean but can kick up to 10W of grunge...people can and do gig them with a sane drummer.
(Off topic or WHAT!!)
Yeah, totally off topic but that's where these kinds of threads tend to go. Next thing you know I'll be telling you about my dogs....My name is also Dave, incidentally. So, hi Dave from Dave.
Anyway, the 34B is back together and works. I traced out the wires to the power supply PCB, just in case some goes wrong on THAT end of those wires, I know where to look. I don't ever want to open this thing up again but ya never know. It's like an old car you want to "restore". You spend more time under the hood than in the driver's seat.
Hah! Ha! My grandson has just bought his good lady a sausage dog pup for her birthday...900 quid!!
OK. I'm reading about 6v there. Not 15v. Wait a second.....plugged it back in...... I've got meters and sound from the headphone amp! You nailed it! I've got some intermittent bad connection there, surely. Man, you're a lifesaver! Now the question is: Do I just put it back together as-is or do I pull the motherboard again to inspect the other side for more wonky solder joints? I don't want to pull the motherboard again. It's a pain and who knows what I might mess up on it, just doing that. I already reflowed EVERY solder joint on there.
I had an A 3440 at one time and IT was built like a tank. Same for my 80-8, it never gave me the misery that this machine has. Well, now I know where the (solved?) problem is. I think I'm just going to clean the pins and connector with isopropyl, make sure they're tight and hope that it stays fixed. And if it goes south again, well, I know what I have to do then. Again, a million
6V where? Between pins 9&11 or pins 10&11, or both? Is it still 6V? The audio chain will function at 6V, but that doesn’t mean it’s functioning right.
What kind of meter do you have?
If it’s still 6V I would also measure for AC volts between pins 9&11 and 10&11. It should be 0.
Also, I would never ever apply abrasives like 600 grit sandpaper to connection pins. The connectors used in machines like the 30 series are standard-grade…thin tin plating. If you apply abrasives it may temporarily help, but when you compromise the plating you accelerate the return of oxidation. I would only, if absolutely necessary (like if there is a lot of oxidation on them), use fine steel wool or fine and broken-in scotch brite pad, and typically not do any of that and simply apply DeoxIT D5 and exercise the connections. If needed I would use DeoxIT Gold or D100. In nearly all circumstances the D5 and exercising does the trick, and does the best job of maintaining the plating integrity. The threshold for what is considered “taking a hammer” to the problem is low on a machine like the 30 series, relative to a more professional machine with higher quality glass fiber PCBs, gold-plated contacts and connections, etc. Approach and handle with care.
Yeah, 6v. It's a digital muti-meter, Tougs M103, set to vDC. That seemed odd to me seeing the rail at +/- 15v. Didn't think to check for AC. Not a single capacitor has been changed in this machine, ever. I was pretty delicate with the sandpaper, just here and there where I saw discolouration. Iso and then,well, not DeOxit, KF something. I do notice the meters dimming when going into play which made me raise an eyebrow. The machine now functions, plays back at the correct speed and exhibits no other real problems. I did, with the help of the schematic and board configuration, trace the wires back to where they go on the power supply PCB. Seems to be quite a few electrolytic caps on that board. Would that be a potential cause of only seeing 6v? I also spotted a bridge rectifier. Tired diodes? I'm not a tech but here in rural Corsica, I'm as close to one as anybody's going to get. Oh, it's a 110v machine. I'm using a Bronson++ 1000 watt power transformer to power the machine. I know it doesn't change the AC (50/60 Hz) frequency, but the machine DOES run at the correct speed. That's what I known that's where I'm at.
“Yeah, 6V.”
6V where? I keep repeating the question…between pins 9&11 or 10&11 of J171? Or both?
Caps and diodes don’t regulate the voltage here. The regulators regulate the voltage. But a failed bridge or main filter cap or regulator can cause faults like this. Also, thanks for sharing the very important detail you are operating a machine designed for 60Hz on 50Hz. Yes if it runs it’s going f to run at the correct speed because the capstan is a DC servo type with its own clocking. An AC capstan motor would lock to the line frequency and run slow at 50Hz if it was expecting 60Hz. But your bigger problem can be, depending on what the voltage is coming out of your conversion transformer, at the lower line frequency, that rectifies lower than 60Hz at the given input voltage, and may be too low for the required level at the input of the regulators. So help me understand where you are measuring 6V. Please be specific. 20 questions can be a fun game but not here. If your +/-15V rails are outputting +/-6V, you have a problem. And the next step is measuring for AC across pins 9&11 and 10&11 of J171, and if you have AC there you need to find why.
Sorry, both. J171, I confirm. Equal on both sides, well, 6.3 and 6.0v. 9-11 = 6.0v, 10-11 = 6.3v. DC. Or the other way around. Ok, I'll take the back off again tomorrow and check for AC. Those main filter caps would be on the power supply board, right? Along with the bridge rectifier? I know where that is and, boy, it's gonna be a bitch to get to it. Forgive my ignorance but what does a regulator look like? Is it one of the transistor type things that usually bolt to something or require a heat sink? I repeat, I am not a tech. And yeah, my 80-8 ran slow but was fitted with a dual pulley capstan. Moved the belt over and that was fixed.
Okay. Yeah something is not right for sure if both sides are running around 6V. That’s with J171 unplugged from the motherboard?
Yes the main filter caps are on the Power Supply PCB, C806 & C807, and C812 & C813…pairs of 470uF caps running in parallel. Honestly that seems undervalued to me. I’d probably replace the pairs with a single 2,200uF cap each side. That’s probably a little overkill, but it’s not too much, and it’s hard to find caps in standard values between 1,000uF and 2,200uF.
The rectification on the +/-15V supply is actually discrete…4 diodes mounted to the PCB.
The regulation is also discrete. Often times they use standard 78xx and 79xx regulators that come in a TO-220 package, so they look like larger 3-pin transistors. But the regulation for the +/-15V supply on the 34B is discrete meaning they used an array of transistors for regulation, Q806, 807 & 808 for one side, and Q809, 810 & 811 for the other…Q808 & Q811 are output power transistors that are mounted to the PCB and fastened to a heatsink. The rest are smaller packaged parts like TO-92 mounted to the PCB.
What you really should be using at this point is an oscilloscope so you can actually see what the waveform of the power is as you move up the supply circuit. You can still try to use the DMM but it’s less effective and can be ineffective at identifying the fault depending on what it is. I forget…has this always been a problem, or were things fine and then recently they suddenly weren’t?
Because the supply uses discrete regulation I have no way of knowing what the minimum voltage threshold is at the input of the regulator circuit. It would be interesting to know what the DC voltage is at the input of one side though, like measuring from a node between the base of Q806 and R814 to ground. But that’s for later maybe. But if it’s always been a problem it may just be the input power and line frequency are to little power. Step 1 is measure for AC volts at the power supply outputs.
Yes your 80-8 would run slow unless it had the optional DC servo capstan. Most had the AC capstan.
Holy shit, that’s a lot for a non- tech like me to digest but I get the general picture. I’m going to have to read this 12 more times and google a bunch of things. I don’t have an oscilloscope (and to tell the truth, don’t know how to use one). Your information is invaluable however and I’m pretty good with my hands and learn quickly. Thanks again.
Oh and yes J 171 disconnected from the motherboard.
One further question: all of the components you spoke of are on the power supply PCB, right? That would make sense to me but just wanted to confirm that. 40 year old caps are not ideal, huh?
Sorry, one last thing. The machine had been in storage since about 1999. I had loaned it to a friend and have no idea where it was stored. The belt and pinch roller had turned to tar so I replaced both and reconnected those fiddly little springs for the return arm dampening. Transport is fine. Then intermittent playback - no playback. Reflowed the motherboard and all was well until it wasn’t, bringing the current problem to light. That’s where I am now. It’s functional but, apparently, far from ideal. I’ll get there with your help and, really, thanks again.
Discrete voltage regulator circuits vary a bit but most of them use a series power device and there must be a voltage reference somewhere. That will be a Zener diode or maybe two Zeners in series. If that voltage is present and correct (it will be marked on the diodes and should be on the schematic) the next check is the input voltage to the series transistor which should be a few volts higher than the wanted 15 volts.
Yes they are all mounted to the Power Supply PCB.
And it depends on the caps. There are computer grade screw-terminal caps in my Ampex MM-1000 from 1967 that are still in-spec. But most of the caps used in something like a Tascam 38 can typically benefit from replacing at this point. Teac used good quality caps of the day. They still work fine a minority of the time, just not as well as they should. Caps do different kinds of things depending on their application in a given circuit, so whether or not an out-of-spec cap is a noticeable problem depends on its function and the type of circuit, and in a lot of cases it doesn’t impact functionality, but rather performance quality. Wholesale recapping is not typically mandatory, but usually there’s some benefit. I recommend focusing on power supplies first if you’re going to do anything. And of course there are times where replacement is necessary, and those situations are going to continue to increase as these devices age.
Can you verify your meter make and model is Tougs M103? I can’t find anything like that…was trying to find the manual or at least specifications. Thanks.
