F
frnkfrkl
Concerning Step 1, Yes, that's what I thought. But where is it? There are bundles of wires bundled to other bundles of wires so tracing from the secondaries of the power transformer is a daunting task. If someone could tell me which pcb has that power rail and where on that pcb (left-right up-down, next to the red connector, etc.) I might find it, that would be really helpful. Perhaps there's just one connector in there where the pins aren't conducting, that seems to be a chronic. problem with this unit which is why I reflowed the entire motherboard. Other than connectors, is there another component that would be primordial in causing this problem? I saw relays mentioned above but I've not seen a single relay on any of the boards that I can see visually at this point of disassembly. Lots of transistors, though. I really just need to narrow the scope of where to look. Thanks and I appreciate any insights / info the community might have about this. As I said before, my competence is limited but I'm not a total dummy and I learn quick.Sounds like everything audio is out. IIRC the headphone amp has a separate power supply from the main +/-25V audio power rails. Step 1: check the audio power supply.
