This is a side-note here...
chassis grounding...look at that system schematic on 8-5/6 again, and particularly in the upper left of the schematic at TB1, J1 and the Power In connector. Again, J1 is the input of the 24VDC regulated supply. TB1 is that screw-terminal block mounted to the breaker panel. Notice that the ground from the Power In connector goes to the chassis, to TB1 and branches to J1. Guess what? On my MM-1000 the ground comes from the Power In connector straight to TB1, and then
from TB1 to a stud on the metal breaker panel, and then...that's it.
This is not good right? The breaker panel is just a 2U rackmount panel so even if IT is connected to ground, there is no gaurantee that it will conduct ground to the rest of the chassis. It is painted metal, and a fairly heavy coat at that, and
that's supposed to ground the rest of the chassis?? And, you got it right, there is no ground to the 24VDC supply. I pulled J1 apart and there is just hot and neutral lines in there even though there is a lug for a ground. So I'm thinking regardless of anything else I need to run a ground line from TB1 to the 24VDC input J1,
and also star-ground the rest of the chassis including the transport plate??
