sweetbeats
Reel deep thoughts...
Thanks for the additional info.
So you didn’t disassemble, clean and relubricate the reel table drive mechanism?
I have no idea where the noise is coming from…if it was me I’d be getting out a mechanic’s stethoscope or even using something like a chopstick to my ear and probe around to narrow down where the sound is coming from. But it sounds like it could be the reel table drive mechanism. What lubricant did you use for the other mechanisms? Did you check/adjust the capstan thrust bearing?
The irregular behavior from the supply reel…I only see it happening with that one UDII CD60 tape. Does it actually happen with other tapes? Could it be a problem isolated to that tape?
Fairly fresh tire…how do you know…? Do you know it’s been replaced or is it possible it’s the original tire? The biggest mistake I feel people make when refurbishing a vintage cassette deck is doing nothing more than putting eyes on the rubber parts, feeling them and if they subjectively see okay chalking it up as good. If the parts are original, they need to be replaced at this point…period. New pinch roller, and I *highly* advise against going the cheapskate route which is doing nothing more than getting a replacement “donut”…get a complete replacement roller, and preferably one from Athan. And get the replacement reel table drive assembly idler from Tascam. I can’t remember if it’s in this thread or not but there’s an updated part number and it was cheap, and they had stock at least a couple years ago. There’s just no point in going to the trouble to pull the transport assembly, tear it down and not go the distance with what should be done if you want it to work right, or at least mitigate potential causes to issues. I’m not trying to be overly critical, I’m just speaking from personal experience you 100% get out of a cassette transport refurb what you put into it, and the rubber components can look and feel okay, but what you can’t see is how they’ve become mis-shaped over time or know without a durometer and the original spec whether or not the parts are actually still good, and there is a small margin of serviceability for these parts. And the bottom line is in 100% of the machines I’ve worked on from the 70s, 80s and 90s, which includes your 238, the rubber components were past service life…every time.
Help me out…what board are you calling the “controller board”? The Control PCB? And what bipolar caps? Give me the part designators…C__ and C__ etc. on what PCB assembly? Ceramic disk caps rarely go bad. The only time I see them fail is if they are in a sustained over voltage condition or high heat condition. That’s not the case here…these are not the droids you’re looking for. And think of it this way…I don’t believe your issue is electronic. In PLAY mode the supply reel is not driven. The tape is precisely driven by the capstan, and the reel table drive mechanism drives the takeup reel to provide takeup tension. In this transport there is no holdback tension at the supply side, it is passive via the friction of the cassette itself. So there’s no servo control or electronic control of supply side holdback tension in PLAY. Your issue is mechanical. There is no electronic drive or control of the supply reel in PLAY. And, again, I’m only seeing your issue with that one cassette, so please clarify if I’m seeing that incorrectly.
By “scrubbing” are you talking about the strange noise, or something with the scrub/shuttle function? And, again, I disagree there is any issue with transport control. I think your problem is mechanical.
Parts of the mechanism cleaned/regreased are the reels, capstan bearing, brake levers. Original grease on the head plate is good for now.
Secondary motor was pulled out and idler inspected, fairly fresh tire measured 10mm at outer diameter.
Wondering if other components on the controller board are bad - I didn't have the replacement bipolar caps so left the old ones in, other ceramic caps there seem to be involved in the play control too.
The scrubbing seems strange and mechanically related but there's a probability of the controller needing more work.
