sweetbeats
Reel deep thoughts...
In terms of the actual power I wold suspect that the light did not lite because the voltage dropped from the 100+ volts no load to something much lower. thus a much lower wattage.
Ah. Right. The lamp becomes a voltage divider right? And I can put my meter between the household ground and the plate and watch what happens to the voltage when I connect the lamp in series, yes?
Perhaps disconnecting everything near it one by one without frying yourself or your machine will help find the source.
Right...but that's also part of what is baking my noodle...there is one sole connector that interfaces the transport with the rest of the machine...it is J2, a round 37-pin amphenol connector. 14 of the conductors are used out of the 37. EVERY ONE OF THOSE 14 PINS IS CARRYING AC VOLTAGE...like between 11 and 33 volts. I posted detail up somewhere earlier in the thread.
So I can get the ill behavior to stop by pulling J2 at the transport. We know it is coming through there. I've tried disconnecting every transport component from the transport-side of J2, and the plate is still charged.
Doesn't seem to me that there should be constant AC voltage on those 14 pins nor does it make sense that it is getting to the plate if I unplug everything from the harness.
And it further doesn't make sense that there should still be AC voltage on all those pins if I disconnect the wiring harness from everything else in the machine, which I have done. I've taken the relay box, 24VDC supply and 39VDC supplies out of the loop as well as the control panel. I've even taken the internal AC power harness out of the loop (by making my own cable to go from the receptacle to the MM-1000's breaker panel). So that's everything. Its just basically wall receptacle to the transport connector J2, but if I measure for continuity between the hot and neutral legs coming into the machine and the plate there is zero continuity!!!
Do I recall correctly that you measured little or no voltage between the protective ground and the neutral wire at the outlet you are using?
Yes. And I'll check that again.
, but I'm definitely frustrated with the MM-1000 when I see it or think about it.
