muttley600
Banned
Neck through is sposed to be more stable and allow easier access to upper frets.
Not sure I agree there. Neck thru theoretically has the disadvantage of the centre warping or pulling beyond the truss rod.. Once that happens it is fubar to a large degree. However if done properly and using a laminate construction that problem can be minimised. One of the main problems with thru necks is that any repairs to badly adjusted neck sets or twisted necks is costly. I wouldn't agree that they have more sustain than a set neck which is a common belief.
Each design has it's pro's and cons. None is "better" or "worse". I quite like the idea of thru necks with a top plate on them because it hides the thru neck and helps add strength where the truss rod ends. I also like the compact solution of tenoning the body section part into a one piece body either from in front or behind. Theoretically you should get much of any perceived advantages of a thru neck with added stability without adding the cost or weight of a cap. Most solutions will work if you do them well.
