snow lizard
Dedicated Slacker
For what it's worth I'm not really a huge fan of the ADA sound. I know you love that thing, but to me it sounds like the '80's in a way that I would not describe as good. But hey, that's just me. What do I know?
If LF boominess is an issue you might want to think about mic choice. The M88 has substantial proximity effect from having a flat and deep low end response and a very directional pattern. You could compensate for it with EQ, or use a mic like an SM57 or 58 that rolls off the low end. The position of the cabinet in the room has an effect as well. You can reduce bass buildup from early reflections by getting the cabinet off the floor if it's a combo or something, or placing the microphone on one of the upper speakers on a 4x12. Having the cabinet backed up to a wall will do the same thing, so if your cabinet is on the floor in the corner of a room you're getting early reflections from 2 walls and the floor. Move it away to get rid of that.
I also find your guitar sound is often kind of scooped in the mids. It could be the way the EQ is dialed on the ADA. Could also be mic positioning or the mic itself. If you place a mic right on the grill cloth of a cab and sweep it from firing right at the center dust cap to the edge of the cone, this is one of the most powerful EQ controls you have. SM57's are described as midrange presence peak microphones. The M88 is different. It's not right or wrong to have a scooped guitar sound (Fender blackface amps come to mind) but it has to fit the track. You can compensate with EQ in post to an extent, but getting it right at the source as Farview suggested is preferred.
