bouldersoundguy
I wouldn't use a HPF, I'd cut with a low shelf or a 2 octave (-ish) band. I generally just do my best during tracking then make the final adjustments in post.
Yes. I had stated the problems I had with using the HPF to counter the proximity bass. More experience needed there fore sure. It became like, farther away.Lazer, I think, needs to experiment with EQ - LPF and HPF
I used thin.I can't think of better words to explain.
Im sticking with ADA.I bought a Line 6 Variax and a Line 6 floor board processor. These can produce virtually any sound I want - but it's not the nicest guitar to play, but the nicest guitar sounds so boring?
The M88 was 1 foot away.Further up - Laser said something about dynamics and always being a distance away? I wasn't;t quite sure what he meant - but maybe that slightly weak sound is just a distance from the mic thing?
Look at the bar? How do the peaks look.I didn't get to listen to it
The tone knob on board the vehicle? A tone control is subtractive. So it is commonly used to dull a shrill sound. 10 would be as close to open. 'Tone' circuit cut out completely would be wide open. A 250k pot still sounds open and round, nice and strong, and needs little capacitence in the tone control. Like .10-.20 uf. The resistance, adds needed treble, naturally creating potential. As you go up in volumn knob potential, 500k will require more tone capacity. Like 1meg pots are shrill as hell, so you control it back to presentable with a .6+ uf cap. Potential value increase there is a bad game. You start taking away more than you are putting in, it ruins the attack eventually. The most tactically adept move would be to lower the potentials of the knobs and run the thing as wide open as possible. Purest tiny signal amped with a 9 volt. Using ACTIVE PICKUPS. Switching to 10k pots not 500k. Massive body.but if the guitar is too boomy, adjust the guitar tone.
You are over thinking it. If the sound you are getting isn't what you want, change it. What the electronics are doing to change the sound is irrelevant. This isn't a philosophical exercise, it is about getting a good tone.Look at the bar? How do the peaks look.
From the preamp's point of veiw, you want as much pick attack potential as possible, with the least ammount of capacity. You would NOT play starting on 1, on the tone knob. Not how it works. Potential and capacity works the other way. Once you have the dynamic signal into the preamp you do what you want with it.
Thats what I say anyways. Pretty sure some of it is fact.
Right. Man, I thought the record player sounded just like the amp in the room.it is about getting a good tone.
What the amp sounds like in the room doesn't matter. What it sounds like on the recording does.Right. Man, I thought the record player sounded just like the amp in the room.
Yeah..You're probably right.What the amp sounds like in the room doesn't matter.
