D
djclueveli
what waves plugins should i use on vocals and what order should i put them in. Eq, Compression.........and so on. Also does anyone use the frequency chart when mixin. if so what do u use it for.
djclueveli said:that wasnt my question lol but anyways i bought the platinum version back in the days just to let you know
Farview said:Until you define what needs to be done, you can't know what tools to use.
Robert D said:Hereby nominated for quote of the day!
-RD
djclueveli said:what waves plugins should i use on vocals and what order should i put them in. Eq, Compression.........and so on. Also does anyone use the frequency chart when mixin. if so what do u use it for.
Ford Van said:So, are all you guys saying that you cannot advice a couple of signal chains to put on a vocal?![]()
And the comment about buying something expensive and not knowing how to use it. Give me a BREAK!!! I have seen person after person here drop big cash on expensive stuff thay have NO idea how to use! So, it is far from unprecendented!
You will want most likely an eq and a compressor on the vocal. Whether you eq first then compress, or compress first then eq really depends on which way achieves what you are after in the sound.
You just gotta experiment.
So your advise would be an EQ and compressor. How groundbreaking. You should have told him about a de-esser, or are you saving that for the advanced class?Ford Van said:So, are all you guys saying that you cannot advice a couple of signal chains to put on a vocal?
Sillyhat said:So your advise would be an EQ and compressor. How groundbreaking. You should have told him about a de-esser, or are you saving that for the advanced class?
sushi-mon said:You paid so dearly for the platinum version, but you don't know how to use it ?![]()
leddy said:I wonder why he chose Waves over the UAD-1 pack. Most folks seem to like the UAD-1 better...
