Eliminating mic hum with balanced cables
  • Thread starter Thread starter Frink
There are plenty of overhead fed homes here in Suffoll. My town is pretty modern - fibre cable passes every home in an early town adoption scheme - yet some of the main roads have overhead, Causes grief when more than one person on a pole wants a car charger.
I have had 4 macbooks (plus a G5, various imacs and a mini mac - and none of them have ever had hum issues when plugged directly into a mixer or PA - ever! I have also had lots of windows laptops and few have been hum free. Plus ALL Dells are going to hum. No idea why, they just do.
My old Dell hummed with the power supply connected. My newer one didn't.
In the performing arts center where I work, the headphone output of one of the iMacs buzzes when connected to the compact Midas mixer. Using one of those cheap behringer USB-RCA interfaces solves it.
I understand they only use Ally for overheads because it is much lighter than copper ?
I got the aluminium thing by chatting to the guys digging the street up to fix it.
Maybe because it IS modern? Northampton is a very old town. I grew up in a very old part of it surrounded by shoe factories and the mains came in through the wall in the cellar (for coal which we used for about 12 years of my life) I think there is a council estate (as was, most have been bought now) Hardlands Rd which might still have OH but then that is in what was a village before even my time called "Duston".
Yes EV chargers will be a problem whatever your electrical service. Many roads simply don't have the amperage capacity to allow a charger in every house. The solution is pretty simple...Solar.
Why would a hairy arsed guy digging the road up know FA about metallurgy? Heh! I am going by the premise that where I live has been around since I was a snot nosed kid! I had an aunty who lived in the next street from me and dad and I visited every Sunday. She had the same style bungalow as mine so by that reckoning the wires in the road have to be at least 80 years old and I am pretty sure we did not use aluminium back then. I seem to recall there was a post WWll scheme to use ally instead of copper for house wiring (not in'road) but it went south because of cathodic reaction with copper in sockets and such?
They have ripped up the road to change the gas pipes to plastic and the same for water but they have never put in new power cabling AFAIK ? Why would they?
About a year ago I had a smart meter fitted and the electric Co had to come back and change the metal box which held the incoming cable...should have asked!
That's one problem with relying on solar to charge an EV. I used to drive 100 miles/day minimum when I was working. By the worksheet Tesla publishes for the Model 3 (the lowest tier), I would need roughly 12-15 400W panels just to charge the car using typical US sunshine. That will run about ~$15-18,000. The problem, especially at this time of year, is that I was leaving about 7am and getting home around 6pm. Sunrise is around 7:30-8am and sunset is 5pm.
So during the time the my car is sitting in the garage to be charged, the sun is shining on China, not the my house! Moonglow doesn't give you much electricity, so that means I'll need to have a hefty battery pack to charge during the day. Since my Model 3 will be using about 25kWH per day, I'll need about a 30kWH battery system. That runs $10-14,000 more in addition to the solar panels.
A Model Y adds about 10%, a Cybertruck increases things by 50% over the Model 3. Of course if you can afford a Cybertruck you probably have enough for a big Powerwall and lots of panels to cover the estate house AND the stables for your polo ponies, and probably the servant's quarters!
Or, I can just drive up the street and spend 20 minutes a night at the Supercharger. That's going to run around $10-12/day. That's $2000 to $2400/yr. Luckily there's a coffee shop across the street, so I can sip on a $7 Pumpkin Spice Latte while munching on a $4 Cinnamon Streussel Scone every night. Working 200 days/yr at $11/night is $2200/yr. And I probably need a gym membership to take care of the weight I gained from eating all those scones!
Dang, I didn't realize that driving an EV was so expensive!!!! 💲💸💰
Ha! Ha! Luckily Rich, it don't work like that! The "problem" is the lack of capacity in the feeds to individual streets (at least in UK. No idea about Pole Pig Land!) so if those that need EV charging get some solar it will reduce the total current demand overall. Called the "diversity factor". You can have as many 13A outlets here as you like and each double socket can deliver up to 26A but not ALL of them ALL of the time!
By the way, I worked through Maggies war with the miners and the 3 day week. To save power the electricity boards, as they were then, reduced the supply voltage. That would actually make things worse today. I wonder if anyone here can tell me why?
Switching power supplies?
Shot in the dark but I think they either maintain desired output voltage or fail, so I'm guessing efficiency suffers compared to old transformer/rectifier supplies where output voltage just drops a bit?
Yup! Not just SMPSUs either. This struck me when a TV mnfctr brought out an all solid state CTV with a thyristor* regulated supply. As line voltage falls the device maintains the same power output and so must draw more current. Just about every electrical device is regulated in some way these days.
*First models just used half wave rectification and the power companies were NOT happy about that!
