In the beginning.....I used to compress the heck out of everything and that of course was a disaster. Then I went for a while when I put it on sparsely among various tracks because of the aforementioned disasters. And I felt there wasn't enough compression in the appropriate places.
But there must be a medium course of action, a basic compression workflow method I could use.
I use Reaper, ReaComp, and I have another plugin for compression I sometimes use which also has other features such as gate, EQ, and deesser (Schepps Omni Channel). Any suggestions would be greatly appreciated.
Man... I probably run at least SOME compression on most things, but how much...
I guess rather than trying to really answer your question, I'd suggest this - every once in a while, just dedicate an hour or so to pulling up some instruments or a full mix, and just
play with compression. Start on individual tracks first, and at first definitely stick to compression plugins that show you gain reduction as it's happening. What you want to do is learn to really HEAR compression; ten or fifteen years ago I'd have told you that compression used well was something you shouldn't hear. Today, I'd say sometimes that's true, but sometimes it's
not, and learning to really hear what a compressor is doing, and then once you've gotten a feel for one, experiment with a few other types of compression and learning to hear their unique "flavors," and then take all
that and then just go and do a lot of critical listening and really try to
hear compression in a mix...
I
still feel like this is a work in progress for me, and to be fair I think most of the last ten years music sort of took a backseat to training on a road bike... but if I look at the mixes I was doing ten years ago and the ones I'm doing today, I think the single biggest improvement I've made is I've gotten much more confident working with compression than I used to be.
EDIT - I guess this might help with an example.
2:28 or so, as you come into the chorus... Adams really lays into a chord or two, and you can hear what to my ears sounds like an opto compressor really mashing the acoustic guitar. It happens in a few other points, but that's a really clear example... and, it's probably a mistake and Adams checked himself into rehab shortly after finishing this album so he was probably out of his mind on something... but I also think the way that acoustic kind of gets "squishy" and blooms sounds awesome.
And, especially in a less sparse mix, you'd be surprised how far you can get away with this before it even really becomes audible, except when the guitars are solo'd.
EDIT #2 - ReaComp is great, btw, I've got a bunch of other "color" compressors I like, but it's super transparent, and very flexible. I use it a lot.
