Eliminating mic hum with balanced cables
  • Thread starter Thread starter Frink
F
Frink
I'm just starting to bring my old 'bedroom' studio up to scratch - starting with eliminating as much buzz and hum as I can from the mic chain.
I have this chain for vocals and mic'd up instruments:
Mic (Rode NT3 or Shure SM58) into JoeMeek Pre-Amp with an XLR
JoeMeek into an Alesis EQ
EQ into DBX Compressor
Compressor into PC
I was a bit of a newbie/clueless hobbyist when I started, so I used a Normalled Unbalanced Patchbay connected with basic TS 1/4in jack cables.
I got a lot of buzz, but as my hobby was quite low-key, I managed to eliminate it using some VST plug-ins on my DAW.
Now that I'm getting a new PC and some new equipment, I've replaced the patchbay with a balanced unit and have replaced all the cables with sturdy TRS 1/4in balanced cables.
This, perhaps not unexpectedly, has made a big difference to the mic hum/interference.
The problem is now that I'm becoming obsessed with using unbalanced gear - so I have a couple of questions:
My new PC will use a MOTU M2 interface which IS balanced, so I have no problem there.
But I also have another PC that I use for regular work so I will route this into the main amp for everything.
This other PC has a simple single mini-jack stereo output, so to connect it to the patchbay and amp, I would use a splitter that converts the stereo mini-jack into two 1/4in jack outputs into which I can put regular cables.
The splitter/adaptor takes the stereo line and splits into 2 mono lines which means that the connector does not have TRS connections so, I guess, that makes it unbalanced.
Question: Will this matter? i.e. if I have this unbalanced device connected to my amp, will it create interference on the mic even though its not in the recording chain?
If not, then problem solved - I'll carry on as is.
But if this unbalanced section of my setup does cause interference, how would I convert a stereo mini-output into two single TRS balanced outputs to the amp?
Thanks for listening and maybe for answering - it's much appreciated. :)
Frink.
Connecting a computer 3.5mm stereo out to two jacks is almost guaranteed to be trouble free on a mac, and likely to hum and buzz on a PC - just the way it seems to work with PC audio. Unbalancing a balanced input rarely makes much difference, but people spend lots of time making latops buzz free - A DI box is a great way of providing isolation, but you can buy. This gizmo solves the problem. It's British, but I am sure you can find similar in your location.
adaptor
adaptor
Many thanks Rob - I am based in the UK so if you have a particular gizmo in mind, I'm all ears 😁
The work PC can introduce a ground-loop path through the amp/patchbay even though you are not recording its audio, but an unbalanced connection does not automatically mean a noisy recording.
Before buying anything, compare the same short mic recording with the work PC's audio cable connected and then disconnected at the amp/patchbay. Keep the mic gain, routing and other connections unchanged, with noise-removal plugins bypassed for the comparison. Turn playback down before reconnecting. If the recorded hum does not change, that cable is not presently causing the mic problem.
The mini-jack's TRS carries left/right/common; splitting it to two TS plugs is the normal stereo breakout. Swapping those plugs for TRS cannot create two balanced outputs. If that particular connection is the culprit, the audio isolation approach Rob suggested addresses the ground path. His word "adaptor" above is already a clickable link.
Sound Devices explains why this depends on the complete connection path:
Thanks for your advice.
I must admit it's very tempting for me to try to solve all of my setup issues BEFORE I start purchasing the new kit but, of course, there's nothing like the hands-on approach of testing every part of the setup in situ to isolate any potential problems. I'm kind of in that 'calm before the storm' where I'm excitedly waiting to get going but trying to get as much prep (both practical and theoretical) done as possible!
I'm checking out your link as we speak. Oh - and thanks for the 'adaptor' link hint. I missed that :ROFLMAO:.
A very easy way is to buy a Mac - that solves a host of PC Problems!
This one - CPC Farnell - got me out of trouble many times and really cheap. https://cpc.farnell.com/pulse/pls00550/ground-loop-isolator-3-5mm-to/dp/AV25544
cpc link
I'm not really following the relationship between the two computers. Sounds like, essentially, two separate setups?
If that's the case, and you're really just asking about a computer's line output to amplifier, then no your separate mic audio path shouldn't be affected.
You'd use a device with balanced outputs, an audio interface, instead of the built in output.
There's no reason built in output can't be fine and perfectly usable, though.
The problems with unbalanced runs come from using long cables and/or running near power supplies and other noisy devices.
Get a short splitter and try it - There's a decent chance it'll be just fine.
You'd use a device with balanced outputs, au audio interface, instead of the built in output.
Thanks for your reply and help on those 3 topics:
i) The 2 computers are unrelated, but they will use the same amp and speakers. My concern was that, although PC2 is nothing to do with the music setup, could the lack of balanced cables have an adverse effect on the whole system because they're sharing the amp. You can probably tell that I'm not an electronics guy!
ii) I think I've been trying to solve all of my problems BEFORE buying the PC and equipment. I'm feeling now that the best way is to check everything when I'm setting it up and then try to solve noise problems IF they arise!
iii) That's a good reminder - I've been obsessing a bit with TRS cables but I also need to keep connections short AND try to separate power units and leads too.
Oh, cool. Thanks for clarifying.
Yeah, I mean, in simplest terms a cable is carrying audio from point A to point B.
Balancing technology cancels out the majority of noise picked up along the way, from other nearby devices.
Whether there is any appreciable interference to pick up or not depends on the environment,
but also on your cable length and path.
Realistically either the output of that second computer (the built in audio one) from your amp will have hum on it, or it wont,
but the other computer and other audio paths are unrelated/unaffected.
If the cable run is short and not near power supplies, transformers, etc, it should be fine.
One thing I used to do with a couple of cables was wire a ¼" jack, unbalanced, or 2 x 3.5" in stereo from a computer, to pins 2 and 3 of an XLR, with no connection to ground. When merely plugging in some gizmo caused all sorts of hums and buzzes, sticking it into a mixer XLR with transformer of differential preamps would often remove the hum as there was no ground path. It was never guaranteed, but a couple of these cables always used to be in the cable trunk.
The issue of ground loops and balanced operation often get lumped together but are really not the same things? Whilst it is true that going to a FULLY balanced signal scheme can often fix a ground loop that is usually because the equipment connected together is made to a better grounding standard. It is often possible to cure a ground hum by lifting a ground at one end of a cable (BUT NEVER A MAINS SAFETY EARTH!!!) but this can then sometimes make the gear prone to RFinterference. That however can usually be fixed with a capacitor.
Balanced operation ONLY rejects low frequency noise, mainly mains hum and its harmonics (it actually works SO well that we used unscreened twisted lamp wire for 30 Ohm mics with nary a buzz...then folks started putting transmitter in taxis!) Ground loop hum is caused by two or more pieces of gear being earthed twice. A classic is an active speaker with a 3 pin IEC mains socket fed from an AI or mixer also earthed and then the two tied together with another earth in an audio cable. Often taking mains power from the same outlet for both or all pieces of gear can help but sometimes ground isolation is the only remedy.
Those cheap transformers do work and give acceptable sound quality but, for a PC headphone source they will be working at less than a volt rms. Try one at +4dBu and with a +20dBu headroom and it will probably start to sound rather gruesome! Also, PC headphone outs are not noted for hi fidelity.
Another solution is the aforementioned 3.5mm to 1/4" jacks adapter but use 100 Ohm resistors in the ring circuit to convert to an "impedance balanced" output also try with and without the screen connected thru' . (can attach scribbles if required) There are of course much better quality 1:1 isolating traffs, Art Cleanbox is one.
I am intrigued to read that macs are immune to ground loops? Not having one to try I would love to know how that works? Does it apply to towers or just laptops? BTW laptops usually don't buzz on battery power because very often chargers carry the mains earth through to the DC side. I have had a "universal" Duracell charger for years with a bi-pin mains inout. Seek them out but beware cheap, dodgy imitations, one took out my mains power a few weeks ago!
Fixing noise/hum/RFI problems is always a "one off" issue and each job must be tackled in a systematic manner.
Meant to say...the world has turned and now more and more equipment is being made earth free, class ll insulation. This can result in a whole recording setup not being earthed at all! This is not dangerous (but you might feel "tingles") but can cause hum. Solution is of course earth one piece ONLY in the setup.
In the US, most equipment that doesn't have the 3 prong grounded plug at least is polarized. One tab is larger than the other so you can't plug it in backwards. All neutrals and hot wires should be the same, as long at the main wiring is done correctly, which any competent electrician would do.
I can't say the same about when your dumb brother-in-law says he can do the wiring for your new room for free! ⚡
I know nothing of US home wiring save I think most have dual voltages? UK drums just have a single 230V* phase although some very large £M house might have a 3 phase supply for heavy machines.
Most of our homes have "Protective Multiple Earthing" this means you have live and neutral coming in, usually from armoured cable underground and the neutral is bonded back to the armour at the meter/consumer unit (fuse box) From there the house power goes out in 2.5mmsq PVC cable to all the outlets and earth is served with an earth wire as well. We have a "ring main" and of course each power plug has a suitable fuse, mostly 13 amps but small stuff should be 3A.
I am no "electrician" but have knocked about with a couple of good ones a fair bit. I am YEARS out of date with modern regulations.
*That is "EU harmonized voltage" in practice the private rip off merchants rarely bother toichange the taps on local substations so most of us get the old 240V supply. Last I checked mine it was 245V.
I have had 4 macbooks (plus a G5, various imacs and a mini mac - and none of them have ever had hum issues when plugged directly into a mixer or PA - ever! I have also had lots of windows laptops and few have been hum free. Plus ALL Dells are going to hum. No idea why, they just do.
They never changed the UK 240V.
They just tweeked the plus/minus in the spec, so that it encompassed both Europe and UK.
I check mine twice a day now, and also before I switch my studio stuff on.
The cables in the ground are aluminium, and when they get wet the aluminium turns to dust, and you then get overvoltage.
It does no harm to plan ahead, of course, but you can get paralysis too.
At some point yeah, just bite the bullet and see if there's a problem or not.
The crucial thing, that few people seem to get, is if there is a problem, you can, and should, diagnose it properly.
I see more and more random guesses "oh, buy this adapter, buy this converter, but this blah blah" without knowing what the problem is,
and some inexplicable resistance to just going and finding out.
Reminds me of "buy more memory" regardless of what the computer performance issue is,
even though there's a performance monitor sitting right there waiting for you to look at the "CPU : 100%" indicator. :facepalm:
In the event that you have any issues, come back and tell us.
It's very easy to differentiate between ground loops, unwanted induction, software/driver issues etc with a little thought. :)
The cables coming into my place have been underground for about 100 years so I think they are copper. I understand they only use Ally for overheads because it is much lighter than copper ? Very few premises in UK are served by overhead wires, at least not in urban areas.
Re sub voltages? When we (Blackstar amps) moved into our first offices (Google Kingsheath Npton) we had breakers tripping out for the first week or so. Each bench had a 1kVa Variac on it and if you banged two or more on together the breaker would trip. Turned out the supply was often 250V+! Once tapped down no more tripping.
My area, Duston/St James once had a lot of fairly heavy industry. Timken bearings, Pollard bearings, Express Lifts factory and more shoe factories than you could shake a kinky boot at...all gone and so has that load and it seems they never thought to fix that! Got some BIIIG Mother subs left from it tho'but!
