What instruments do you put compression on, and what ones you don't?
  • Thread starter Thread starter Eric V
I used to struggle to understand how to use compression.
I use compression in two different ways.
On channel strips, I use compression as a guard rail. What I’m trying to do here is to avoid clipping the recorder. For instruments that don’t have a high peak to average ratio, I’ll set the threshold at about -5 dB, the ratio at 3:1, a hard knee and roughly 5/150 ms attack/release. For instruments with a high peak-to-average ratio, I’ll set the threshold at -15 dB with a soft knee; I also set the channel level 5 dB higher than the levels for guitar, keys, synths, etc.
I also gate every channel. In my studio, all instruments are direct; there’s no room noise, but there’s still self-noise from the devices themselves. I adjust the gate to close when the device is on but not playing.
On the mix buss I’ll use chained compressors to raise the overall level towards the streaming target of -14 LUFS. My approach here is to set the threshold as deep as possible (roughly -45 to -60 dB, depending upon the compressor), maximize attack/release times and use a small ratio (typically 1.2:1 to 1.5:1).
This buss compressor usage with deep thresholds is the one that always seemed counterintuitive to me. IME, it’s much easier to use math than one’s ears. You need to know the noise floor of your recording. You need to pick a target noise floor for the intended listening environment. If you’re going from a -70 dB studio noise floor to a -45 dB target noise floor, you’re removing 25 dB of dynamic range. The overall compression ratio in this case is just 70 over 45, or about 1.55:1. I’ll spread this across two compressors to avoid breathing and pumping; the ratios are multiplicative so about 1.25:1 for each compressor.
I have a limiter at the end of the mix buss chain in order to limit peaks, aiming for a target of -2 dBTP.
My postproduction workflow is to edit unwanted parts of the 2-track recording (this could be as simple as removing top and tail, but might also involve removing dead air between sections) and raising the level the rest of the way to -14 LUFS, with another limiter to control peaks.
Thank you for the detailed response, very appreciated.
You put compression on everything - or nothing - it depends on what reproduction of sound you want.
I know there's a lot of advice here already and mine may be redundant however, when things have a large dynamic range (drums, vocals, acoustic instruments and bass to name a few), and they are to be mixed then their collective average volume that you hear at any given time determines what will be heard and what will be obscured. Use of stereo space / panning and also the instrument's focal frequency will provide cut-through or separation but when you have competing instruments in one spectrum you'll profit from controlling the peaks like kick with bass or vocal with keyboards & non-driven guitars.
Multi-band compressors can be the best so you can separate the attack from the body or secondary onset. E.g. the kicks presence is around 2-4k and its resonate body is usually 50-125hz. If you compress the range of 50-125hz and do the same for the bass guitar or synth it maintains headroom for the 2 or 3 instruments to coexist. Whereas with vocals and non-driven guitars, it is too easy to get over expressive in section and cut way above the average level of surrounding instruments and also loose tonal character in quieter sections as volumes slip below this average respective volume.
In some styles it is common to add drive (not in a gritty way) to vocals, keys and bass to give then a stronger character and normalise their volumes. It should never be a rule to compress the f... out of everything in the quest for "volume" as it steals the attack /punch of things and loses tonal character... not to mention noise floor.
If you were to offer an example piece we could be more pointed in our advice and experience.
Cheers,
Andy
Cheers,
Andy
Thanks Andy! Ok, I used little or no compression at all (I can't remember without checking) on this one.
Ok, some Zeppelin. Here's what I'm hearing. Driven guitar pan left bass with minor effects down the middle, keyboard also central, vocals with light verb slightly off-center-right, electric drumkit and feature guitars 50+ % right of center.
* Driven guitar has considerable compression just from the nature of distortion gain - no compression necessary - EQ fixes problem frequencies
* Electric drumkits have limited dynamic range as their sound library is already "produced" - however the hats are too high in the mix.
* Bass sounds controlled - not too present or muddy in the mix.
* vocals are also quite controlled dynamically. This is where compression is almost mandatory - Very Ozzy Osbourne - perhaps a little back in the mix - consider + 1 - 2db up in the mix.
* Keys are upper register so there's no bottom-end muddiness that can come from mid to lower registers which would require strong eq below 160hz to give room for bass & Kicks. - all good in mix
Overall, I would double the primary guitar to give it a richness. I believe the original has cello / violas doubling the guitar riff to this effect. Midi could easily program this if you use a suitable software like FL Studio or Logic. I use this commonly in my recordings and recently had AI re-render my midi to "humanize it" (see my post Progressive Waltz 24).
Lastly:- USE A CLICK TRACK. The drum groove in this piece is what gives it the effect. When the drums get a little loose, things can fall over a bit.
Overall this is good work. Be encouraged.
Cheers
Andrew.
Cheers
Andrew.
I used the original song for the timing. I usually use a click track but not with this - I played to the original song. The guitar is doubled by the synth. I have lots of strings to support the riff as the song builds. And not to excuse "loose drums" but I'm not a drummer. I do my best. WYSIWYG basically. But you made some good points, thank you.
I watched a Youtube video by a music college teacher.
The students wanted to put a load of plugins/inserts on every channel, caus that's how you get great mixes.
His rule was to allow the students to do just one thing to each channel. Could be an EQ adjustment, or could be compression, or some other thing.
That makes you think hard about what is actually needed.
I think restricting the Students to one item per track is a clever way of getting to mix and pan correctly - as for what we need - isn't that dependent on the music - the one item per track (I think) would only work if you had a very straight forward recording - I feel different plugins add excitement or put the candy into the music.
For me, little to no compression. Compression has been a relatively new addition to recording tools.
Back in the day with 4 track or maybe 8 track (if you were lucky) such a thing as an affordable compressor for home recording was unheard of. So you went without, and you were quite happy with it, or should I say ‘lack of it’.
Instead you learned how to watch your VU meters to keep your vocals from going into the red. Same thing with bass, you learned how to control and contain your attack so it wasn’t overloading.
Usually tube amps when cranked would do their own compression.
I ended up learning some skills that I’m grateful for for, and might not have learned had I had the tools.
I notice there's a pervading idea that compression is not a good thing. While I understand that (like gain and verb), it can be something that is easily overused to the detriment of the recording/listener however, I must assert that compression in recording is a mandatory on some instruments / voices.
I would suggest that the conversation would be more beneficial if people were to discuss what | Attack | Ratio | Release | settings they find useful for different applications. You've only got so much headroom to record with and we want to create music that is "release ready" and / or mastered (which is compression and eq at its heart).
Without compression, if you don't want to clip, then you have to keep it quiet or you accept a degree of clipping in either case, your production suffers. Compression has been a popularised mainstay in studios since the late 50s for this reason.
Have a look at my examples below of a fender Strat and 5-string bass - both completely raw with no signal chain. With appropriate mild compression I could increase the volume by 6db (that’s a perceived double volume) and freed up 3db of extra headroom before any evidence of compression was discernible. I could get heavy handed and triple it with no compression evidence in a mix environment.
Hope to not offend guys - Cheers
Cheers,
Andy
Multiband compressors are really great! They are great, but I don't use them often.... If I use them, I do it on bass mostly.
