H
Harvey Gerst
Harvey GerstOriginally posted by MrZekeMan
Do you think these mics are close enough in performance that it negates the usefulness of having them both?
No, there are voices that have energies in different ranges that will excite differernt resonances in microphones. Even mics that sound this close will sometimes differ greatly in how they handle a specific instrument or a specific voice. If you plan on having a studio, having both makes sense. If it's just gonna be for you and your voice, find the one that works best for your voice and go with that.
I'm a real green horn so this might be a silly question. How much does a 2db hotter signal and 2db quieter translate to sound quality? How big a difference does it make in the final product of your track after you've recorded?
Most of the differences are easily eq-ed, but each mic's overall sonic signature will vary depending on angle, distance, intensity and the material being recorded. It can often take several months to hear the subtle differences between two similar mics (and it may not make all that much difference if your application isn't all that critical). After you pass a certain level, the difference is in inches, not feet.
Since there has been such hype about the C1 compared to the U87, do you think you will be able to A/B them and give us the low down on them? It would be interesting to know the real scoop on them. To see just how similar they are.
I can, but I won't. As Dot pointed out, he had to make some eq adjustments on the order of 3 dB (that's double) at several frequencies to make it sound the way he "remembered" the sound of the U87.
The U87 is a multi-pattern mic - the C1 is not. The off axis response of the two mics will be different, the basic sonic signatures are different, and the overload and distortion characteristics will be different, simply because of the different manufacturing philosophy. But on a quick listen, most people just won't hear any big difference.
Under the right circumstances, I can easily make a Shure SM-57 sound as good or better than a U87 - FOR SOME THINGS. That doesn't make a 57 as good or "just like" an 87.
Thanks for your hard work on our behalf Harvey. I owe you a few cold beers if we ever meet up.
Zeke
I'll settle for a couple of Cokes.
Your a good teacher
