L
LouisVuittonK
I have a
M-Audio Nova Mic
Type: Large diaphragm condenser, gold evaporated
Polar Pattern: Cardioid
Frequency Response: 20 Hz-18 kHz
Sensitivity: 16 mV/Pa (-36 dBV)
Max. SPL for 0.5% THD: 128 dB
Equivalent Noise Level: 14 dB A weighted
Output Impedance: 200 ohms
Recommended Load Impedance: > 1,000 ohms
Preamp Topology: Class A FET preamp
Power Requirement: 48V phantom power
Connector: 3-pin male XLR
Grille and Body: Wire mesh grille and body, all brass
Finishing: Silver nickel plating
Size: 7.3 in. (h) x 1.9 in. (w)
Weight: 23 oz.
A MXL V67
25mm (1 in.) large capsule condenser
Gold-sputtered, 6 micron density diaphragm
Solid state preamp balanced transformer output
Durable brass enclosure/span
Technical Info
Type: Condenser pressure gradient mic with large 25mm diaphragm capsule
Frequency Range: 30Hz-20kHz
Polar Pattern: Wide Cardioid
Impedance: 200 ohms
S/N Ratio: 74dB (Ref. 1Pa A-weighted)
Equivalent Noise Level: 20dB(A weighted IEC 268-4)
Max SPL for 0.5% THD: 130dB
Power Requirements: Phantom Power 48V ±4V
Current Consumption: <3.0mA
Size: 47mm × 184mm
Weight: 1.3lb
And A AKG Perception 120
Type 2/3" Diaphragm True Condenser
Polar pattern cardioid
Frequency range 20 to 20,000 Hz
Sensitivity 22 mV/Pa (-33 dBV)
Max. SPL 130/150 dB (0/-20 dB) for 0.5% THD
Equivalent noise level 22 dB-A (IEC 60268-4)
Signal/noise ratio (A-weighted) 72 dB
Preattenuation pad 0 dB, -20 dB
Bass filter 12 dB/octave at 300 Hz
Impedance <200 ohms
Recommended load impedance >= 1,000 ohms
Current consumption <3 mA
Power requirement 48 V phantom power to DIN/IEC
Connector 3-pin XLR
Finish metallic blue
Dimensions 53 dia. x 165 mm (2.1 dia. x 6.5 in.)
Net weight 525 g (18.5 oz.)
Shipping weight 955 g (33.7 oz.)
So which one is the best ?
M-Audio Nova Mic
Weight: 23 oz.
A MXL V67
Technical Info
Impedance: 200 ohms
Size: 47mm × 184mm
Weight: 1.3lb
Impedance <200 ohms
Connector 3-pin XLR
