F
fgonza2
you may have a tension problem. Are the tension rollers moving down as the tape winds so they trigger a stop ? can you shoot a video when that happens ?
I didn't even notice that, until I posted the video. I then went to try and even out that wobbly flange. The bottom one was fine. Plus..these reel centers aren't the best fitting, Lots of play! Both these Clampers and the MS-16's.Beck, Curious why you say that "they" appear too high. I actually set the reel heights prior. The take-up was only slightly low. Thanks.
OK. But as I read the manual (and I could be totally off) the Tension rollers height/azimuth and the Tach roller azimuth and Pinch roller, and capstan azimuth all come into play. No pun intended! especially in REW and FF modes.
So I'm a little confused when you say " The only thing in the tape path before that is the reel itself" I assume when you say "first" tape guide you mean the one on the far left or Guide #1. But, there is a Tach roller, and Tension roller, in between it, and the reel.![]()
How was the winding tape pack quality before you started off in this project to rotate the lifter arms and rotate the guide posts?
I ask because it wasn't stated if there was uneven tape packs or issues with the tape curling up on the guide posts before you started this project. Nor did you state if it was only that one roll of tape that shows the issues or if all your tapes do. These details are important if we're to offer you valid advice.
If all was well, then you shouldn't attempt to mess with anything other then what you had done on the lifters and guide posts. But if you then start messing with reel table heights and tensioner arms before establishing that what you initially did was the problem, then you only end up compounding the issues and making it harder to get it all aligned as it should.
Cheers!![]()
But they appear to be fine. Some unevenness to them but not bad.
Can't do the 350 and 500 g. measurements required. Mine is the T2 H5 UMC
The spring anchors are used for tension adjustments per the manual.
What manual do I use? one, the other, or combination of both?
