A
AnalogApples
Active member
Hi helpful friends! I modified my Tascam MS-16 amp cards and speed to be 15ips. It’s now also modified to have additional bias current available.
So I bought a reel of ATR master tape.
My calibration tape is 250nWb/meter.
If I want to get the most out the headroom for this ATR tape, how will I change my calibration process?
1.)Do I just calibrate playback to be -6dB on the meters??
2.) Then when calibrating the record levels, do I increase the voltage of my signal generator? What voltage am I aiming for?
3.) someone said there’s a switch under the bottom panel of my Tascam Amp card section that selects +8, -10, etc. This complicated things for me. I’ll dig into the manual and see about this but if you can give me the nutshell of how this changes the calibration process, thank you.
4.) I’m using a Tascam M-3500 board. Can I just use the test tones from the board and set the VU meters on the tape machine for -6,8,9(?)…?
I just want to say thanks, I’d be lost without this community.
