Tascam M-___ Story...
  • Thread starter Thread starter sweetbeats
"pro"
I wouldnt worry too much about what the "pros" think, they havent churned out hardly anything that ive found brilliant in years.
If modern professional producers are "pro" at anything its over-polishing boring art to the point that it seems exciting enough to fool the general public into believing its something special.
I cant remember ever loving a song because of how flawlessly state of the art the fidelity was.
A classic thread. This mixer is beyond cool and with the care and feeding you're providing it'll be in service for the rest of your recording career. Excellent work Cory!
Disassembled channel strip #2...decapped all the PCB's and removed the same 11 opamps as channel #1. Did the cleaning and DeoxIT treatment. They are all ready for new caps and reassembly.
Still working on channel strip #2.
Also found an addon balance converter module for the M-__...okay I'm kind of stretching it...I got an LA-40 mkII but I got it for pretty cheap and it is minty...just needs some cleaning up:
I'm looking for a second one now and with that I'll have 10 the capability for 10additional balanced +4 outs (aside from the STEREO outs) and be able to bring 8 balanced +4 returns to the board. This is important because my plan is to interface the M-__ with my Ampex MM-1000 8-track and a pair of LA-40's would allow me to utilize the balanced I/O of the MM. In that case the pair of LA-40's would be connected to the BUSS OUTs (the outputs of the 8 program groups), and to the LINE2 inputs of channels 1 ~ 8 (LINE2 is intended to be used as tape returns since LINE2 can be directly sourced in each pair of AUX sends 1 ~ 2 and 3 ~ 4 for cue feeds). The MM will accomodate unbalanced +4 or +8 inputs and outputs, but it is also fitted with transformer balanced I/O and I may like the sound of that path -OR- (because it is such a noisy beast) I may eventually need to place it in a different room or further from the board than is prudent for unbalanced cabling...I am a home recordist after all and often track in the same room as the mixing and recording equipment while operating said equipment so keeping the recorder and mixer close together in a different room while I track in another won't typically work.
Beware: long drawn-out tech-geeky kind of stream-of-consciousness below...I have a feeling this may well extend beyond most people's attention span...just giving you the opportunity to get out now.
The LA-40 is a neat and simple device and I expect it will do what it does transparently which is what I want, and will enhance the functionality of the M-__. Not that I'd ever use it for a live board but I think about those kinds of things for fun and as a mental exercise to get to know the board even better; how would it be interfaced and operated in different environments and such. This led me to some pondering about how would it do as a live board...IS it well-endowed as a live mixer as much as it is a recording mixer? Some of this pondering was spurred by a recent discussion in another thread comparing some of the features of the Tascam M-500 and M-300 mixers and a major conclusion was that the M-300 mixers, though "only" a 4-buss family of mixers, are much better suited for live work because those subgroups can be routed to the main buss with the push of a switch (plus there is a dedicated mono mix control). Can the M-__ do those two things (recording and live work) equally well and simultaneously as a dual-purpose board? The short answer is yes, though it is definitely designed with recording in mind and I think the main thing I see at this point that sticks out in that regard is that it doesn't have a direct and basic/simple path to route the program groups (the 8 subgroups) to the main mix. Typically in a live mixing situation, at least in my experience, the subgroups are there as a convenience tool for the operator...individual channels can be routed to the groups in families of like sources thus reducing the number of faders the operator has to operate for coarse work...then each subgroup would have a switch to dump that group to the main buss. This is different than in a recording situation where the subgroups are used more like a variable patchbay for your recorder tracks. Of course you still would often be grouping individual channels to groups in families of like sources like for instance submixing multiple drum mics down to three tracks and such, but the point is that in that recording situation your routing to subgroups is sort of a means to that end...mixing however many mixer channels down to that many subgroups for the recorder, and then of course you monitor those in stereo, but the focus at the recording stage is the level and content of those groups for those recorder tracks as opposed to a convenience tool as a means an end, the stereo or mono main mix. The M-__ subgroups do not have a direct way to be routed to the main mix. You can SOLO what is available to route to the groups on that channel (the PGM SOLO), you can SOLO what is present on the group out present on that channel module (BUSS SOLO), and you can monitor what is present at the BUSS OUT jack via the MONItor section on that BUSS OUT jack's channel module because the MONItor section can be sourced to "BUSS", but there isn't a "STEREO" or "L-R" routing control after the BUSS MASTER level control. So how is it done? A bit kludgily...
The source selected at each channel's input select switch is automatically routed to the main mix. Rather than most routing sections on contemporary mixers where you would route a channel to "L-R" or some such thing, the M-__ channel's automatically go to the main mix but there is a ST MUTE switch, which in effect works just the opposite of the typical "L-R" routing switch in that you would switch the MUTE function in it to turn off the main mix routing, and turn the MUTE off (switch in the up position) to route to the main mix. So I could MUTE the routing path to the main mix which is after the path to the subroups so even with a channel muted to the main mix I can still route it to the 8 subgroups. So far so good. Now to get the group sums to the main mix I'd have to source each channel's MONItor section to "BUSS", and then use the MONI TO STEREO function which would dump the signals present after each channel's BUSS MASTER pot directly to the main mix. This would leave the monitor mixer unavailable for use in monitoring other things, but if the board was being used as a live board and the groups were to be used as a convenience tool for submixing then I'd probably want to be monitoring them with the monitor mixer anyway. And in spite of that bit of kludge I'd still have rapid group source switching via the GROUP A and B REMOTE section as well as the REMOTE switching for the monitor mixer. AND, I don't loose out on a mute control for the subgroups because there is a mute control for each subgroup that stops whatever is routed to that group, and there is also a mute for each channel's monitor section, AND there is always the big orange master mute kill switch. Another fun fact to consider is the ease of dedicating the EQ section on each strip for the subgroup that lives on that strip...if the eq is not needed for the input source and I'd rather or I need the EQ section for the subgroup then it is the simple push of the EQ TO MONI switch and now the EQ section effects the monitor section in the channel which would make it an EQ for the subgroup if the group was being routed to the main mix via the monitor section --> MONI TO STEREO function. And how handy to have the two "rumble filters" (50Hz and 150Hz) as well as the low-pass filter that are active even if the EQ section is bypassed...nice feature for live work...often times in small venue situations (and depending on the event type) one microphone could be being used throughout the production for multiple sources. I find it hand in theese situations to be able to setup an EQ curve for one of those sources that needs it the most and be able to bypass the EQ for the other sources. Just drop it in when needed, but what a shame it would be if the two HPF's and the LPF were only active when the EQ was active...the M-__ was setup right IMHO because you can strategically switch the EQ in and out without effecting your use of the other filters.
If I wanted to use the subs in that way but still wanted the board to be used for multitrack mixing while being used as a FOH mixer then I could use the direct outs, which don't get killed by anything...so the channel faders could still be used to control that and I'd montor off the recorder via the LINE1 or LINE2 inputs on the board (can use the REMOTE section for quick monitoring of that without disrupting the main mix) or even use the pre-fade/pre-eq jacks on each channel to send to the recorder and still have the channel faders available for detail mixing and the BUSS MASTER knobs for convenience submixing. We haven't even talked about the AUX sends yet...and if I had a couple LA-40's then all AUX sends could be on +4 balanced sends for monitor mixes to the stage, and I could even use the STUDIO outs in a pinch as a limited and mirrored pair of monitor sends since there is some independence of source selection there and a dedicated level knob. OROROR! The STUDIO outs could go to a delay processor and then to the LA-40 and THEN to an amp rack for balcony speakers...:eek: SWEET!
So, though it'd have to be operated a little non-traditionally by contemprorary standards, the M-__ would still function well even in a live dual-purpose application...the number of channel strips would be its biggest limiting factor...that and arguably the number of AUX sends too. So it'd be limited to a small hall, BUT, it could do it especially with those LA-40 converters. Too bad there's no M-__-EX (ala M-5EX or M-35EX...) You'd have to look back early in thread but I imagine the R&D folks at Teac were planning for that possibility in the design concept as there are terminals on the motherboards to connect each buss (subgroup, AUX, monitor, main, etc.) to something, and a blanking panel on the back that looks like a good size for a hefty cascade connector...alas, an 8 or 12 channel M-__ expander 'tis not to be...Ive also mentioned before that there is evidence of capability for balanced I/O as seen on the vast number of unoccupied pads on the output PCB's as well as space for additional XLR jacks on the jack panel...:eek:...but the LA-40 is going to be a nice companion.
Nice man!, I actually just stumbled through the original thread when shoulderpain picked this up. It's really hard to believe how far this board has come.:)
Well I missed out on that M-312B but from what it sounds like your saying I should go for an M-___ ;)... nah just kidding, remember portability was a prerequisite, oh yeah and Tascam having made more then one so I could actually get one.
I made it through the tech-geek stream of consciousness and it sounds like you have some serious flexibility in this board... and that you are always discovering more! The only part that gave me some difficulty (and I would be glad if you could clear this up... as I see it all the time and feel a little dumb not knowing) FOH? Front of house??? That's the best I can come up with for it, just wondering if it's accurate.
A couple of LA-40's seem like a great add-on to that board (although a custom built M-___ expander card would be awesome! I can see why that's unlikely though)
Hope at some point we get to hear something done by the M-___, MM-1000 combo!
"FOH" yeah...sorry. Euphamism for live mixer but specifically for the house as opposed to a stage/monitor mixer which you sometimes run in a larger setting. FOH does indeed stand for Front Of House.
You missed out on the M-312B? What happened?
Yeah, the M-__ is a monster of features and routing. Sometime I want to do another video tour of it since that would probably demonstrate things in a more digestable way, and you can rest assured that at some point there will be samples of M-__/MM-1000 productions posted up here. :)
Nowhere near as exciting as an M-__/MM-1000 production sample but here is a song that was tracked to my DAW but the vocal track was done through the M-__:
No need to apologize... :) That's what I figured but I've kept seeing it come up and wanted to confirm that I was thinking correctly, thanks for letting me know.
Eh I couldn't get up there 'till the weekend and someone else managed to snag it first... oh well, Living down in So. Cal. you would be really surprised the amount of Tascam/TEAC stuff that comes up on a regular basis for extremely cheap. If I wasn't so against shipping I think someone could make good money off of ebaying Tascam gear off the L.A. craigslist.:D I'll find another one or something else suitable, just gotta keep my eyes open.
Wow man, that sounds really good, I dig. Hope you don't hit any major bumps in the road with the MM-1000 so we can hear that soon!
Mr. 'Sweetbeats', I havent had a chance to participate in discussions with you on this forum, but for now I just wanted to extend my appreciation for all the great Info you have posted, its AWESOME! If there was some type of Nobel-Prize for Teac/Tascam analog recording equipment, you would definitely be the deserving winner of it :)
Just a short introduction: I'm 45, soon to be 46. I remember when I was a teen in the late 70's my older brother bought an A-3440 brand new along with Model 2A mixer & MB-20 meter bridge, which I thought was just the coolest. (He still has them too). I also remember 'Modern Recording' magazine from back then- luckily I saved all those issues, and picked up a few more on Ebay in recent years that I didnt have. (I get 'Tape Op' mag, and its good, but the ol 'Modern Recording' was the best !)
I hope to do some remodeling in my house soon, and setup my equipment in the basement, and also in one bedroom upstairs. I acquired some recording gear a few years ago but havent had the extra time yet to use them, so I really want to get underway soon, but I think I still have alot ot learn- have to study the operating manuals.
I have a Tascam 48 and I recently sold my M308 and upgraded to an M-512. Also have A-3440 with Model 2A/MB-20. Tascam 32, M1B line mixer, and also have a Teac X-300R and an ol A-1200U. I dont know if I have much use for the ol 1200, so I may just give it to a friend, I'll see.
Anyhow, Just wanted to say Hi. Please dont stop posting- your messages and Info provided here is truly great.
Regards,
Fred (New York)
Fred, a sincere thanks to you for the sentiments and encouragement. Sometimes I feel a bit like I'm posting in a vacuum because often times I don't get replies. Its my own fault because much of what I put up is rhetorical, and I have come to realize that much of what I post up is more sizeable/voluminous than most want to or have the time to sift through, BUT I also remember that these "Story" threads I've started were originally intended to document the Story first, so I am glad they are of some benefit and/or enjoyment for others as well as myself.
And BTW, really gracious of you to nominate me for the Teac/Tascam Nobel Prize :D:D:D, but if there was such a thing I could not accept. I am so young in this area of audio technology it would be a dishonor to the countless others that know so much more than I, even within this forum community...the same "others" that are responsible for literally most of what I know...maybe they could give the prize to a group. ;):p
Even though my scope has recently widened and even shifted to include vintage Ampex equipment, It will never shift away from or leave the Teac/Tascam world. History of the 70's, 80's and 90's has been written and cannot be changed. Teac produced some of the very best products. They were innovative, relatively affordable with unsurpassed build and engineering quality in the market bracket they created. And the build quality compared to today's "home recording" products? Nothing holds a candle IMHO...might be short-sighted and if I am I'm good with it because every time I crack open an 80's vintage Tascam product I'm met with innards that were thought through and weren't compromised to meet price brackets the way it happens today. In present times I feel there is a divide between "home" and "professional" audio products...the Teac/Tascam products produced during the analog era mentioned above shaped professional features into a package for project and home studios but the sights were always set on a professional standard, and I think that sight is gone.
BTW, 48 and M-512...SWEET combo! ;)
Regards,
Fred (New York)
That's some real nice words Fred. Cory has done a lot to help me with questions I've had. His story (step by step) threads can help anyone who is trying to take on a similar project and needs guidance. Some he even posts video. I like to see things in detail, and he never let's us down. Have some points on ol' dodge.
The pleasure was all mine to extend my appreciation. As I mightve mentioned, I hope to spend more time on this site, learning and contributing. I presume you guys have the Teac/Tascam book on their company history?, its excellent.
Got that book and read it cover to cover. It is good. I wish there had been more detail about products in the 80's. A completely comprehensive book would be quite an understaking, but there were a lot of holes that way. BUT, the accounts of the company history are priceless. It gave me a whole new perspective. I've had dialogues with the author and he wasn't setting out to publish a catalog of Teac/Tascam products throughout the ages...that's just my bag, though. :o I agree that (based on what I think you are inferring) any Teac or Tascam enthusiast would enjoy it. It made me feel more proud to be an owner of Tascam gear. It is a unique company and Randy Alberts did a great job amassing the info that backs that up.
Here, Here! :)
Edit: D'oh, just realized this said M-512 and not M-520. I wanted a M-512 but found none in my area, and wound up with a M-520. The 20 channel board is better for me after all, though, because all of the weird patching I do. How about two four-tracks, an eight-track, a two-track deck for effects, and a two-track half-track deck for mixdown? :)
Woo hoo!
My second minty LA-40 mkII will soon be on its way for 90 bucks shipped!
:D
Channel 2 PCB's are recapped and 11 opamp sites are socketed...Just need to reassemble everything and channel 2 will be officially refurbished...
La-40
Those LA-40s not only look cool but also seem really useful.
It looks fantastic
I love the way the lights look on the board in the dim light. Such a beautiful job you have done. :)
awsome find
i love the look of Tascam stuff. that Beast is AWSOME thanks for sharing :D
The stock for the trim panels has been selected...
And will be getting planed this week:
I found a couple matched pieces for the side panels:
My fingers are officially sore...
I removed the knob and switch caps for channels 3~12 tonight to start getting them cleaned up. 10 channels, 67 controls per channel...you do the math. My index fingertips are numb.
Also, LA-40mkII #3 is on the way. I already have two and all they need is a little cleaning up...very minor. #3 looks to be the same. Got it for $53 shipped.
With the 3 LA-40mkII's the M-__ will have a total of 14 +4 balanced outs and 12 +4 balanced inputs, and having 12in and 12out of those on outboard units gives me the flexibility of using them however is needed. 8in and 8out of them will be for buss outs and line returns for the Ampex MM-1000, 2in and 2out may be for two-track send and return...depends on which two-track deck I end up using and how far it is from the mixer, etc. The last 2out will be from the CONTROL ROOM out jacks. The LA-40mkII will bump those -10dBv unbalanced signals to +4dBu balanced and from there to my crossover and from there to the sub and satellites. This will keep the monitor chain all balanced. And the last 2in? In reserve. Its nice that the M-___ has two jacks on each buss out (and this includes the AUX outs) because I can run on to to an LA-40 input and on to the analog multitrack and the other jack can be connected to a DAW input or something so I don't have to repatch.
