W
waterydomestic
hello all--
i've been dumping tracks from my tascam 388 into pro tools (for eq, mixing, etc) via mbox but i've run into a serious issue. hopefully someone can shed some light on this issue:
since the mbox has 2 inputs, i've been dumping tracks from the tascam 2 at a time. however, it seems that the tascam has been playing back the tracks at slightly different speeds each time. for instance, pro tools tracks 1 and 2 will sync up to each other, as will tracks 3 and 4, etc. however, tracks 1 and 2 will not sync up to tracks 3/4 or any other tracks. this manifests itself in the following way: i'll sync up tracks perfectly at the beginning of a song but it will be noticeably and significantly out of the sync by the end of the song. then, if i go back and sync up the tracks with respect to the end of the song, it's out of sync at the beginning of the song. i know that the recorded tracks are okay, because if i listen to all tracks on the tascam, everything is lined up well.
has anyone experienced anything similar? i replaced the tascam belt recently, so i don't think it's an old and worn out belt. for what it's worth, my practice space is slightly slanted (okay.. quite a bit uneven at one end) so the tascam is not perfectly level. could this be affecting playback speed?
any help or insight would be much appreciated. thank you in advance.
