Studiomaster 16-4-2 Analog Mixer With Original Manual and Schematic, Fully Tested
  • Thread starter Thread starter LeonFreeholdNJ
L
LeonFreeholdNJ
The item is for local pickup only, from Freehold NJ. You will want to test this in my studio to satisfy yourself that it meets your needs before paying. I think you'll be blown away. The preamps are much better than the newer under-$1000 IC-based boards, I've found. Please check my ebay listing below for the full story. The auction ends on 6/19.
I am selling a Studiomaster 16-4-2 analog mixer. Included is the original manual and a component-level circuit schematic (not a block diagram.) The mixer is not a "powered" mixer; it requires an external amplifier for live work or monitoring through speakers. The board is labeled "16-4-2." It was made in England in the early '80s. The schematic is dated 1983. I received this from a friend about 6 years ago who no longer used it. It needed a repair to the power supply, which I did. And it needed spraying of the mechanicals, which I did at the time, and did again in the last few days. This is a very warm, full-fidelity board. The channel EQ has sweepable mids AND sweepable bass. I have not used the board for live work, only studio. It is fully tested and in 100% working order.
Here is the ebay listing:
Studiomaster 16 4 2 Analog Mixer with Original Manual and Schematic Tested | eBay
