sweetbeats
Reel deep thoughts...
So my affinity for the Philips Compact Cassette 4-track multitrack format, and over a decade of curiosity and fascination with the Audio Technica AT-RMX64 all-in-one mixer/multitracker came to a head a little while ago…got my mitts on a straight all-original specimen for a price far less than the insanity that is the current market. It looks like it will clean up really nice, appears to have relatively low hours on it, and came with the factory soft case and original owner’s manual. All that considered, it was a steal at $350 including shipping. it looks like this:
And, no, for that price with the cosmetic condition it’s in and the included accessories it’s not 100% functional…needs a little work…
1. Needs a new reel table drive tire, and as a result it doesn’t currently PLAY and ain’t so good in FFWD or REW either.
2. Pinch roller is *okay*, but could stand a replacement.
3. Several input channels pass signal only intermittently
4. Two meter lamps are out
That’s what I know so far.
For issue #1, I believe the transport, made by Sankyo, is closely related to the transport in a Nakamichi BX-150…looking at pictures of the BX’s Sankyo-made transport and studying the service manual for that machine, it appears to me the reel drive assembly is the same as the AT…those tires are readily available. So I’m going to order one of those at some point and see if I’m correct.
For issue #2 I disassembled the pinch roller assembly in order to test a theory: that the roller is the same as a Tascam 244 (and likely other Tascam units). I was right…same roller specs. And I happen to have a brand new Athan 244 roller here…I’m commandeering it for the AT-RMX64. I *highly* recommend the Athan rollers…got mine off of eBay. Poly instead of rubber, brass hub, and precision mini bearings. It…is a thing-a-beauty. Stock AT on the left, Athan on the right:
[EDIT] I spent some time perusing Athan’s offerings and see now they have a pinch roller for a “Nakamichi Sankyo Transport”. The dimensions match the factory AT-RMX64 pinch roller exactly, so I believe the Athan roller is a perfect match for the AT-RMX64. I have a couple messages out to them to verify, but here is a current link to the product: https://www.ebay.com/itm/2751181460...le5cs0tQ9u&var=&widget_ver=artemis&media=COPY
Issue #3…the plug-in input and mix buss modules are cool. What’s not as cool is what looks like mini-Molex edge connectors to interface the motherboards. Logically I can understand why they picked them, but I think they’re going to need some exercising, DeoxIT-izing and maybe some solder joint re-flowing. The boards are all phenolic resin instead of glass fiber…these intermittent signal issues might not be such an issue with more robust glass fiber boards but…ya can’t have it all. But if you have an AT-RMX64 and signal is dodgey, but you can make it happen by pushing or tapping various places along the affected channel on the dress panel or controls, it’s probably related to the edge connectors.
Last but not least, issue #4, the meter lamps, no sweat. There’s a nice thread right here on this forum started by @famousbeagle where he details a number of issues including meter lamp replacement. I took a gander…easy-peasey, and I think I even have some new meter lamps around here…somewhere.
Here’s a YouTube video that’s nearly 40 minutes of me going on and on about the AT and comparing it to other 4-trackers, looking at the some of the guts, etc…it seemed like 10 minutes when I was recording:
