Monkey Allen
Fork and spoon operator
Hi all, I have a Martin om28 that has had the binding in the waist area become unglued for the past 3 winters as (I guess) both the wood and the plastic binding contract with the change in conditions. Each time over the last 3 winters I have glued it back with Titebond. I know that Titebond isn't the best thing to use because it doesn't work on plastic. I've just done it hoping it would bond some of the original glue that was on the plastic binding to the guitar body, if you know what I mean. That, and I've been too lazy to get the right glue.
So, can anyone suggest a glue I should get for this job?
I was thinking that if the plastic has a tendency to shrink in winter and expand in summer...(and same with the actual wood of the guitar too) should I even be looking to bond the plastic binding to the wood with super strong glue? What will happen in the changes of the seasons? If the plastic binding shrinks will it tear the wood?? Will bad things happen?
I have a Taylor GC5 that has never become unbound at the waist. Solid as a rock. But this om28, not so. And it's only a newish guitar...2014...and the waist binding issues started only 3 or so years into its life.
I'd like to glue the waist binding down once and for all.
So, what would you suggest? I'm in Australia and can not have glue shipped from Stewmac etc. So it would need to be something somewhat generic.
I read this might be an option:
Thank you
Duco Cement Tube - by GEMWORLD online store
This world-famous household cement works on plastic, glass, ceramics, wood, metal & more. Tube has a dispensing tip for more accuracy & the special applicator nozzle won’t clog or dry out. Dries clear, fast & is even dishwasher safe. 1 fl. oz.  Tip: If you're a regular user of super glue or...
					www.gemworld.com.au
			Thank you
