cincy_kid
Active member
Hey all,
Wasn't sure if I should piggy back a previous post or just start a new thread with my question, but I decided on the later. Also wasn't sure if this was the best forum to place it in but here goes:
Basically I am using my Behringer UB 802 mixer and M-Audio Quattro soundcard to do some home recording. I usually lay down a drum loop first to set the tempo and then go onto guitar then vocals, etc.
I only use and will be using 1 track recording at a time, so no need to work out something where I have 2 mics at the same time.
Anyways, I have a 1/4" going from my mixer's FX SEND (mono channel) into INPUT 2 of my soundcard. Then back from OUTPUITS 1 and 2 back into mixer channels 3/4 so I can record and hear all tracks previously recorded as well as the current one I am recording. When I record the vocal track or whatever I am recording with the mic, it will come into ACID 4.0 and be just a mono track. So when I listen to it back to the tracks, I can hear the drums in both ears and the vocals in just one ear. Also, of course, in Acid itself you can see that the drums have top and bottom signal and the vocals just has bottom (mono instead of stereo).
Is there a way, when I am playing the tracks back in my headphones, whether I am recording extra tracks and want to hear the previos ones, or if I am just letting a friend listen to what I have done, is there a way to hear the vocals in stereo like the drums?
I have been told maybe a splitter would work so when I go into the soundcard it goes into INPUTS 1 and 2 instead of just 1. (but the FX SEND is a mono channel so not sure if that would even work..). I have also read on a few threads while researching this problem, that some have suggested some different PANNING options.
Anyone have an easy fix for this? When I make my first wav file or mp3 of my original song I would like ppl to hear it like normal songs and not have the vocals come thru just one side, hehe.
Is this something you just do when you are doing final mix down or mastering?
thanks expert home recorders !
