What is the process for recording my song on a BR-800? Thanks
  • Thread starter Thread starter GMc67
G
GMc67
Hi everyone,
I’ve been struggling to work out, albeit with some success, how to record a song I’ve written on my BOSS BR-80. I have done all I can.
If possible could someone lay out the entire process for me to follow, please? - I’d be massively grateful!
I want to record:
  1. a stereo acoustic guitar track
  2. A mono 12-string acoustic guitar
  3. A Stereo or Mono Bass guitar track
  4. Lead guitar track
  5. 3 /4 x drum mics for acoustic drum kit
  6. 1 x tambourine track
  7. Lead vocal track
  8. Backing vocal track
So far I have managed to mix down the parts 1. to 4. onto Tracks 1&2 (V track 7&8) but I don’t know how to record parts 5-8 and add them to the first 4 parts to complete the song.
I’ve found the BR-800 manual a real pain to follow and I’ve been dipping in and out of using the unit for about 15 years and never really built up any momentum and therefore, understanding.
I’d be eternally grateful if someone could help me, please and thanks!
I find writing songs so cathartic and to hear a finished song which I’ve composed and recorded would mean the world to me!
Cheers!, Gareth
I'm sure we can help - but you've not given us much to go on? We have no idea of what the song is, and we are guessing. I have assumed you are playing and singing everything? Not recording somebody else. You have 4 mic inputs and you have to make a few compromises - like the drums.
First thing though. What exactly do you know and what don't you? You have prepared yourself for bouncing, so you understand at least how to route the inputs to the recording tracks. With this kind of thing, the usual route would be to record the most channel hungry items first, and probably the most important last - so can you get a nice drum balance actually recorded and bounced to two tracks, or can you do it while recording, so only using 2 and no bounce - OR - is it not vital to have stereo drums and they can be one track? For me, I usually need something to play to - so I'd have one track with a very rough version of the song on - maybe with a click - something to lock things to. Then you can start flip flopping. I see no reason ever to record a bass in stereo - even if it is double bass. Bass is so hard to localise, wasting two tracks on bass in my view is pointless. I could probably think of a reason to do it, but when tracks are short, why?
Have you actually worked out how the bouncing works - physically? You need a plan to follow, then follow the plan. Level setting like this really needs experience - otherwise you will start to add the vocals and discover already buried levels are wrong and it is too late. Hopefully with all the virtual tracks - is it 32 or 64? Something daft, you don't have to actually delete stuff. The compromises are the 8 potential destinations are 4 separate ones plus two stereo ones - handy for the drums maybe? With the ability to playback up to 8, hopefully bouncing can be kept to a minimum. The way it looks to me with your list is that you need to get the drums recorded and balanced to stereo early on. The acoustic 'stereo' track. what is that? two mics isn't really stereo it just gives you dark and moody ones side, bright and fingery the other - the flip-flopping left to right can sound quite strange. I may well use two channels in my DAW, but very rarely do they get panned apart. If I was going retro and using a tape style recorder with limitations, I'd just stick with mono. How important is it?
So - does any of that make sense?
  • Like
Reactions: Tru
Hi. I’m recording an original song and playing and singing everything. So if I want to record drums I need to start with an acoustic guitar as a guide but I also need a click track which is loud enough for me to play drums over because the internal studio one is too quiet.
So when I get ghe drums recorded and bounced to 2 tracks, what is the process after that. How do I add other tracks to the drums? Thanks
Here's my process when working on the BR-800. Copied from a post on another site, but it should give the gist of what you can get from the machine.
The complete lack of degradation when bouncing on the BR-800 was a big happy surprise. A copy of tracks 1,2,3,4, and 5 bounced to track 6 results in identical digital copies, just now mixed together as one stereo track.
It gets better. Because you can bounce 1,2,3,4,5 AND 6 to track 6. Without losing the original take that was on 6!
Because each track actually has 8 virtual tracks within it. 1a 1b 1c 1d 1e 1f 1g 1h, 2a 2b etc.
I usually do 6 tracks on 1a 2a 3a 4a 5a 6a, bounce them to 6g, then use that as a backing track to add new tracks to on 1b 2b 3b etc. Vocals on tracks 1h to 5h. Then master everything at the end to the stereo track 6h.
The BR-800 also has an inbuilt drum machine that can be programmed with ins, verses, fills etc, and it is on its own track, completely separate to the ones mentioned above.
Thank you very much for your post, mate it’s really cleared things up for me! Take care, Gareth
I have a BR-8. So much, if not all, is what I wish someone told me when I was using it, which wasn't really that long ago. Now a 2488 NEO.
Also, when you bounce in stereo, as in panned hard left and right, you will lose some volume compared to straight up. And these type of recorders .... what you record originally is what determines your volume of whichever tracks it is. For this and other reasons , mapping it out before is your lifesaver.
I leave you with this..if you find that you can't hear those tracks when they are in the mix, look at the phase relations of the sum.but also possible to double your doubled track and gain volume, after the phases, are correct.
T
Hi everyone,
I want to record:
  7. Lead vocal track
Cheers!, Gareth
I think you have all your tracks full so you can't bounce. Time for choices. I would start there.
T
T
No. Each track actually has 8 virtual tracks. So you don't need to bounce, in theory, until all 64 are full. You can only play one from each track at a time though.
That is right, I forgot about that. I am going to keep you in mind. I have a few songs on that I have always wanted to go back to work on. thanks. the one I have I bought from Japan so I didn't always know what I was doing. I don't read Japanese and this was before phones were what they are today. thanks again
