What Recording Equipment Is Available?
  • Thread starter Thread starter Wabatuckian
Wabatuckian
Wabatuckian
Active member
Hello,
I record myself primarily to improve. I hear the way I want something in my head, and I want to see how close I can get to it. This means recording.
The recording setup that I have right now is cobbled together from a couple mics I had, a mic mixer from 1982, and a cheap stereo player/recorder from Amazon that I had on my mountain bike for times I felt like listening to music while riding.
This last is unsatisfactory. I get the sound I pretty much want from my mics and mixer, but the MP3/WAV player/recorder sometimes skips when I'm recording.
Because I have several expensive hobbies, I'm not looking to spend a lot on a recorder. Mandatory is two tracks for stereo, though four tracks might be nice if I can ever convince my brother-in-law to start drumming for me. Everything gets mixed on the computer, so I don't need anything more than level control which is done on the mic mixer.
Thoughts? Suggestions? Thanks!
MP3/audio file recorders cannot skip? The input sockets can wiggle, and perhaps even dry joints on the PCB can do odd things, but if they actually skip, it's a fault.
I would consider a second hand zoom recorder - these tend to be pretty durable and cheap nowadays.
You know, I thought that too. I have training in computers and have never known a digital device to skip. It's weird. Sounds exactly like a record skipping ahead on playback.
They use a small buffer, so I suppose if the filling of the buffer is slower than the output that would stutter, but that's more like a solid state fault. Or maybe the clock being intermittent so the stream isn't contiguous?
I wondered if it was a buffer thing. I bought it cheap because, if it gets ruined mountain biking, I'm not out a lot.
I'm also recording in WAV and the music I listen to is FLAC. I'm unsure if that would overload the buffer more than compressed MP3.
I'll look at the Zoom models. I saw them on Amazon, but didn't buy because, in the world of cycling, Zoom is known as a cheap brand. I didn't know if it was the same company making everything like Shimano seems to make everything, thus the need for guidance.
I appreciate the help everyone's given so far.
Zoom Cycling is not the same company as Zoom recorders. TOTALLY different.
I've got a Zoom H4n and a Zoom R24. They are older units, the H4N was bought in 2011, and the R-24 in 2013. Both still work flawlessly. The H4 essential is $220, has 4 track, internal + external mics, 32bit recording, multitracking and does 96K recording. The H5 Studio runs $350 but has more capabilities.
Tascam's DR40X is $260, similar to the H4Essential. 4 tracks, multitracking, 32bit/96K recording, internal and external mics.
These are all handheld and can act as an audio interface when connected to a computer. I use mine for mobile recording, pull the SDHC card from the unit and dump the audio directly to my computer for further processing or adding to video.
If you don't need portability and have a decent, current computer, you can buy an audio interface like a Motu M2 for $200, Tascam 102i for $150, or Focusrite 2i2 for $220.
More inputs costs you more money, but you won't need a mixer. Everything is done in the computer. You can get a 4 input Behringer 404Hd for under $150. A Behringer 1820 has 8 mic inputs for $230. Behringer doesn't have the greatest reputation but I think the stuff is serviceable. I have a Tascam 16x08 with 8 mic inputs, plus 8 line inputs. I can record 16 tracks at once on a computer that is 12 years old.
One last route would be something like the Tascam DP24SD or Tascam Model 12. Much like my R-24, you record everything to the unit and then you have the option of mixing in the unit or dumping to a computer. Those will run about $6-700 which might be out of your ballpark. But it's an option.
This is very helpful. I record downstairs and then mix in my office upstairs.
Honestly, the H4 sounds like more than I need, or possibly as much as I'll eventually need. I'll look at it. Thank you.
  • Like
Reactions: RFR
15 years ago, a friend was asking if my H4n could do multitracking. I whipped this up in the living room with 1 acoustic guitar track and 3 vocal tracks, dumped it into Cubase LE and mixed it down. One Studio Projects B3 microphone on a stand into the recorder. Nothing more.
I've got three different models of Zoom recorders and would recommend them to anyone - they are quite cleverly designed so hitting record just works, or as rich says, you can do far more complex things. The essential features like decent noise free preamps and good metering make the case for me.
Son has a DR40x and loves it. He has recorded classical guitar with it and says the result is the same as if he uses his MOTU M4.
But, beginners always concentrate on the input hardware. No matter how good that is you cannot get much of an idea of "how you sound" unless your monitoring system is beyond reproach and to do that with speakers costs $1000s. Headphones can be good at around $200 but is not quite the same experience.
Waba, one other thing. Audacity is adequate for basic recording and editing, and really handy for quick and dirty adjustments, but I would consider looking at a "real" DAW. The latest version seems to be closer to a full DAW, but it's not there yet. One big thing missing is ASIO support which is important if you go with an actual interface and direct computer recording.
Reaper is probably the most popular home recording platform. It's free to try and doesn't die in 60 days. You just get a nag screen at startup but the software still works 100%. A full license is only $60. It's fully loaded with useful plug-ins, and unlimited tracks. Highly Recommended.
Cakewalk Next by Bandlab is free. It also has a big brother paid version called Sonar. I haven't used it, but there a lot of users around the world.
Ardour is a free, open source DAW available for Win/Mac/Linux. Like Reaper, there are unlimited track numbers. I've tried it but Reaper has been my choice for the past dozen years.
There will be a learning curve, but the capabilities are much greater. Some recorders come with limited versions of commercial software. I have a couple of old copies of Cubase LE and had a ProTools Lite years ago. They are a good start, not too intimidating, but are usually limited in various ways.
That's a good song and you do it justice. The recorder sounds good. Thank you.
I'll move up eventually. Right now I need basics; am still learning leveling, fading, etc.
As for monitoring, I need to figure something out. I'm autistic and tonal inflection doesn't come naturally; at least, it's not tonal inflection that most people would think sounds good, anyway. I'm trying to teach myself how to sound decent while still sounding like me. It's getting... Interesting.
My style is more punk/grunge, too. I don't make pretty stuff. I'm not sure if I need the same tools as, say, you, @TalismanRich .
But again, I don't know enough to really know what I need. I'm just a simple guy trying to learn to sing to my guitar.
The issue I have with the DP06 is that you only have the internal microphones. For the same money, the H4Ess and D40DX have standard XLR inputs and phantom power, which means they aren't obsolete when you want to move up a step, and at the same price range. Later on, you could add an AKG P120, AT2020, or an SE X1 A for under $100, an SM57 or 58, Senn E835, or several Behringer SL85s.
Although the H4 has internal mics, I found them less useful that a decent external mic.
I absolutely need to be able to hook up external mics. The ones I have right now have ¼" jacks, but I suppose I could get adapters or just get new mics at some point.
The DP08EX has XLR ins.
"My style is more punk/grunge, too. I don't make pretty stuff. I'm not sure if I need the same tools as, say, you,"
It doesn't matter, sound is sound, if you want to know what you are "putting in" you need to accurately reproduce the output. I sympathize with your present restricted circumstances but do think of improving your monitoring system as soon as possible. Don't mess about with adapters for mics.
About the monitoring: I currently just wear noise-cancelling headphones so I can hear myself. As in, they're not hooked up; rather, they just block external noise so I can hear myself.
When I eventually get an active system, should I feed the guitar through the monitor, too, or just vocals?
