thane1200 said:
frederic......I'm curious to see what you use to organize all your cables. I'm trying to decide if I want to build a giant "peg-board" of sorts, to hang my extra cables from. Any thoughts?
If you mean extra patch cords and mic cables, I've built a closet in the back left corner under the ceiling slant for storage which currently only houses my table saw since I've been too lazy to carry it down into the garage
In this closet on the right side wall will be hooks, similar to coat hooks, which I will be coiling cables and hanging them reasonably sorted. I debating installing something like this:
The drawback of bins and cabling is you know what is going to happen - the cables will invariably overflow the smallish bins and end up on the floor, tangled in whatever else I put in the closet. Hooks are really the way to go. Bins and drawers are great for adaptors (1/4" to RCA, xlr to 1/4", etc) and things like that, so I might do a combination. Making bins is easy, essentially its a wooden "grid" mounted on the wall with sections of wood along the front of the cubbies to prevent things from sliding out. I'm going to start off with hooks first.
In my last "pro" studio, as part of the construction we built a "wiring closet" which was a really cool thing, and extremely useful for us as we had tons of spare cabling and parts. What was done is at the narrow end of the machine room, which was kinda trapazoid shaped, say about 9' at the narrow end, 12' at the wide end, and 16' long both sides, we built a wall sized closet, a mere foot deep. The entire wall was covered with two 4'5" wide doors, floor to ceiling, the ceiling being 12-14' high. Huge, huge doors. The doors opened, and from the floor to about waist high, were wooden cubbies much like in kindegarden class
Above that, on both the back wall and the back side of both doors, were shelving brackets and shelf hooks, with no shelves - the cables were looped over that. Using a pool pole with a coat hanger bent up like a hook wrapped in duct tape, we could get cables from anywhere in that closet. It was great because it took only a foot or so out of the depth of the room, and because it was in the machine room it didn't have to be acoustically treated at all, as the machine room was off to the side and fairly noisey anyway. That's where we put the Otari twins, spare media, etc.
But you have me thinking now... I may use the closet I made in the above pictures for now, but down the road, since I've already made an under-table rack for my recorders and the hot-swap hard drive system for the recorders, I don't need to use the "shower stall space" for recorders, when I redo the bathroom next to my studio. I could easily convert that into a closet and just hang the cables in there. At least I wouldn't have to crawl on the floor to retrieve and return spare cabling. In the picture below, the entry door is all the way to the right, and right next to that is a dark brown slatted door, which is the narrow access door to the shower stall's plumbing. This is where I could put a closet. Would be tight to get into, but hey, why not.
Essentially, I hate drawers and cubbies for cabling. Long term, they end up on the floor or hanging out, and you'll bang yourself on partially open drawers. Hooks all the way. Just have to find a place for the hooks
