MC208
What do you mean still no guitar? The recording has the guitar in it. I made the recording via the USB from the mixer to the computer. Yes, my mixer is from 2012, it's been a great mixer though!
I am not sure of the exact mechanism but the old 16 bit converters in many brands of USB mixers had this problem. Windows defaults the "gain" for the input device at 100% and this results in the hash, similar to what we see in your spectra. The fix is to reduce input gain drastically in Windows Sound Control (as per the attachment) to 5% or less. The hash now drops to around -80dBFS but you have to increase the analogue drive to compensate. A&H fairly quickly fitted 24 bit converters which did not have the problem. We later in fact got a Soundcraft Notepad mixer which was 24 bits and very quiet.Not sure what you meant by (especially the bold part):
If the Zed is an older 16 bit model it is worth checking that attachment and ensure that the gain is reduced to about 5% even less. You then need to 'hit' the converters that bit harder. The hash is not removed but is push down to about -80dFS.
It is older, from 2012 is when we purchased it. I'm not so much worried about the input levels in the computer. If I can hear the hum/hiss at the mixer level, then it will of course be an issue in the computer as well. I forgot to mention that I included a Presonus Blue Tube, and that's where the Samson is getting its phantom power. I'll try taking the Bluetube out and use the ZED's phantom power and see if that gets rid of the hiss.
Well have a bit of faith and try it! Naturally you have to crank up the analogue input level. I no longer have such a device to demonstrate the effect.Level 5 wouldn't even be audible for the input level in windows?!? I have it at 76 as it is now...
