Stand on metal to ground myself instead of a hum eliminator?
  • Thread starter Thread starter Bargarcs
Hmm ok, so what is the solution to the hum caused by letting go of the strings? I know the setup in the instrument is correct. I was told the noise comes from high voltage power lines nearby.
You can get noise through the air with a guitar. Fluorescent lights, digital equipment, transformers, light dimmers can all induce noise that is picked up by a guitar. I can move my guitar around the basement and get more or less noise. That's one reason humbuckers were invented! Single coils are more susceptible to picking up noise. When you touch the strings you can become a shield to some induced noise. Better shielding in the guitar can help a lot. Lots of high end guitars have shielding paint in the pickup and the pots/caps cavities. A shielded pickguard can help quiet a strat or tele. Shields should always be connected to ground.
In no case do you want to use yourself as the path to ground. If there is a poor ground setup in the amp, you can become the path for the electricity to travel. NOT GOOD!
I remember back in the late 60s/early 70s when there were no grounded plugs, just two wire nonpolarized plugs. Amps had capacitors on the power lines. These later were called "death caps" because if they failed, they could put mains level voltage on the ground line.
Many amps had a polarity switch, which would swap the power and ground lines. If your amp and your PA had them switched in opposite directions, and your mouth hit your mic while you held your guitar it could flat out light you up! It was worse than putting a fresh 9 volt battery to your tongue. My Guild Thunderbird amp has both a polarity switch and a "hum balance" which has a pot and capacitor. I learned to walk up to my mic and tap it with my finger.
The fact is friend, guitars and their amplifiers have ALWAYS* been noisy Bs! The amps themselves were often not that well designed for low noise and as ' rock n roll' moved into ever more high gain, distorted sounds this got worse. But, noisy as a 100W amp was, once you hit the strings the headroom was SO immense that the "Signal to Noise Ratio" was in fact pretty good. The drummer had deafened everybody anyway!
The coming of home recording changed all that. That hissy, hummy monster was now a bloody nuisance! As Rich says, single coil pups don't help, all you can really do is orientate the guitar for minimum hum, also check it has cavity screening. Now you can buy an interface with a 100dBFS noise floor for the cost of a decent single malt we want the rest of the kit to be AS quiet. Power soaks can help as can noise gates post tracking.
*The likes of Chas Cristian and Les Paul had access to top amp techs of the day to make quiet amps. They were not in any case into 120dB SPLs nor distortion and Paul was a top engineer in his own right. I am gratified that I was involved in some small way with the development of guitar amps with decent S/N ratios. Say what you like about the "Blackstar Sound" the designs were quiet! I will state that the HT-5 has the best S/N figure of any guitar amp on the planet.
I have ISO transformers on my electrical feeds to my room - have for years - amps and just about everything are dead quiet - I used to use a similar system live and it work work very well - but I remember the days of my Hiwatts (which were relatively quiet) and pedals - thank god drummers are loud!
ISO transformers? Do you mean balanced mains supplies? Probably not so bad when it is about 55V above earth but over here such gear constitutes a big hazard to service personnel who may not realized that even though a mains fuse has popped, one side it still at 115V ref earth.
In fact it is hard to find an isolating transformer here with a centre tapped 230V secondary. There is I understand special provision made for certain medical and scientific uses? You would have to go to a specialized (AKA expensive!) supplier for that.
We do have 110V tools for use on outdoor sites with 55-0-55v traffs, tap to earth.
I use Isolation transformers and Balance Power for the incoming power - it is a silent system completely insulated from any external noise, glitches , appliances etc….and my amps respond according - some of my older amps run at less than 120 - my Hiwatts run and sound best at 105 volts - so I have a few stepdown devices - when the amps get the correct voltage they perform smooth as silk -
That's interesting - virtually unheard of in the UK. Every house has their mains come in and then goes to the sockets and appliances - we don't use transformers in domestic properties.
"I can move my guitar around the basement and get more or less noise"
Yes, same here! Unfortunately, the exact position that the guitarist needs to be, due to filming, in is where the noise occurs. The guitar is a hollow body archtop, and it does have a humbucker. We're not using an amp, we're going direct into the mixer's Hi-Z input. The only thing that has worked to help (not eliminate) the hum, is the wire in the sock trick...
I just have it in my Studio Room - I had a 80amp service wired just to my room - straight from the breaker box.
If the noise changes as you move around, electromagnetic interference is the root problem. You have two choices, eliminate the interference or shield the guitar. Move the guitar around until you find where the interference is coming from and address that. When the noise get loud, that's your clue!
Yeah I guess we're stuck with the noise then, sucks!
You could always install EMG pickups. No string ground required and they are noiseless.
(not recommending or endorsing. Just another option)
Well, hang on! How bad is it? Post a clip* of guitar at -20 dBFS average oriented for minimum hum then damp the stings for say 20 seconds. If your noise floor is better than -70dBFS I would say you are doing pretty well. If significantly worse than neg 70 then you need to investigate noise gates and post tracking software.
There are two ways mains noise gets into the guitar. The primary cause is electro-MAGNETIC coupling. Your pickups become in effect the secondary of a huge AC transformer! There is little you can do about that. Mic transformers can be completely enclosed in "mu metal" which can effect 30dB+ of hum reduction but of course, a totally enclosed git pup would pickup FA! No, humbuckers are the answer there.
A lesser, secondary effect is electro-STATIC coupling and can be virtually eliminated by screening the pup cavity NOT forgetting the back of the scratchpalte.
*An MP3 clip at the best rate 320kHz is the most useful form for me (.wav would be better but we can't have that)
I don't have a clip to post, but I believe the noise is around -40 on the meter. I do use a noise gate, but it's only helpful when the guitar isn't being played. The guitar is usually an archtop hollow body, with Kent Armstrong high quality humbucker pickup. I know the noise is interference because if we move him around, face another direction, it goes away. Problem is it's a video studio, and he kind of needs to be where he is, and oriented in the direction that he is, that just happens to be where the noise comes in.
In that case, record the track with the guitar in the "null" position then video the guy miming to the track. Unless there are legal/contractual reasons why that can't be done. Pretty standard practice in the film work? Post dubbing because the location is just too noisy or the sound is compromised in some other way.
Nobody said all this was easy!
If you getting noise through your guitar which has Humbucking Pickups the problem is either 1. You guitar is wired funky and needs to be fixed 2. the Cable you are using is wonky and needs replaced - one or more of the video devices have a ground issue that needs to be addressed - I would also look at the video monitors and make sure they are grounded properly or get new properly shielded Monitor that don’t leak.
@ecc83 , I want to make an audio clip to post so you can hear it, but I didn't fully understand your instructions. If I record from the mixer to the computer with hands off the strings, and then hands on the strings, would that be sufficient?
OK here's the MO.
Strum guitar to get an average level in the DAW of about -20dBFS in its meters 20secs.
Stop playing but keep a hand on the strings to, a) kill the hum and b, silence the strings...20secs
Lift hand off strings a gently as you can to keep them quiet...20 secs.
N.B. keep level pots as per the first part.
Render the recording as 320k MP3 and attach.
Here's what I did first with the attached file.
The first 20 seconds (about -70dB):
Volume pot on guitar all the way down
Guitar channel volume also all the way down
The second 20 seconds (about -38dB):
Guitar channel volume turned up to unity "0" position as shown below
So the noise is present even when the volume pot is turned all the way down, and gets louder when I increase the volume on the guitar channel of the mixer.
What does this mean?
Geeez! That's nasty! I would not be at all surprised if that is due to the overhead lines. I suspect there is also some electro-staic pickup as well judging by the higher harmonics. Do you know the line voltage?
But WHERE is the chuffin' guitar? The figures mean Jack unless we can refer them to "normal" playing levels.
I shall see if I can post an example.
