MC208
Hmm ok, so what is the solution to the hum caused by letting go of the strings? I know the setup in the instrument is correct. I was told the noise comes from high voltage power lines nearby.
The fact is friend, guitars and their amplifiers have ALWAYS* been noisy Bs! The amps themselves were often not that well designed for low noise and as ' rock n roll' moved into ever more high gain, distorted sounds this got worse. But, noisy as a 100W amp was, once you hit the strings the headroom was SO immense that the "Signal to Noise Ratio" was in fact pretty good. The drummer had deafened everybody anyway!Hmm ok, so what is the solution to the hum caused by letting go of the strings? I know the setup in the instrument is correct. I was told the noise comes from high voltage power lines nearby.
I have ISO transformers on my electrical feeds to my room - have for years - amps and just about everything are dead quiet - I used to use a similar system live and it work work very well - but I remember the days of my Hiwatts (which were relatively quiet) and pedals - thank god drummers are loud!The fact is friend, guitars and their amplifiers have ALWAYS* been noisy Bs! The amps themselves were often not that well designed for low noise and as ' rock n roll' moved into ever more high gain, distorted sounds this got worse. But, noisy as a 100W amp was, once you hit the strings the headroom was SO immense that the "Signal to Noise Ratio" was in fact pretty good. The drummer had deafened everybody anyway!
ISO transformers? Do you mean balanced mains supplies? Probably not so bad when it is about 55V above earth but over here such gear constitutes a big hazard to service personnel who may not realized that even though a mains fuse has popped, one side it still at 115V ref earth.I have ISO transformers on my electrical feeds to my room - have for years - amps and just about everything are dead quiet - I used to use a similar system live and it work work very well - but I remember the days of my Hiwatts (which were relatively quiet) and pedals - thank god drummers are loud!
I use Isolation transformers and Balance Power for the incoming power - it is a silent system completely insulated from any external noise, glitches , appliances etc….and my amps respond according - some of my older amps run at less than 120 - my Hiwatts run and sound best at 105 volts - so I have a few stepdown devices - when the amps get the correct voltage they perform smooth as silk -ISO transformers? Do you mean balanced mains supplies?
I just have it in my Studio Room - I had a 80amp service wired just to my room - straight from the breaker box.That's interesting - virtually unheard of in the UK. Every house has their mains come in and then goes to the sockets and appliances - we don't use transformers in domestic properties.
