MC208
Hmm ok, so what is the solution to the hum caused by letting go of the strings? I know the setup in the instrument is correct. I was told the noise comes from high voltage power lines nearby.
The fact is friend, guitars and their amplifiers have ALWAYS* been noisy Bs! The amps themselves were often not that well designed for low noise and as ' rock n roll' moved into ever more high gain, distorted sounds this got worse. But, noisy as a 100W amp was, once you hit the strings the headroom was SO immense that the "Signal to Noise Ratio" was in fact pretty good. The drummer had deafened everybody anyway!Hmm ok, so what is the solution to the hum caused by letting go of the strings? I know the setup in the instrument is correct. I was told the noise comes from high voltage power lines nearby.
I have ISO transformers on my electrical feeds to my room - have for years - amps and just about everything are dead quiet - I used to use a similar system live and it work work very well - but I remember the days of my Hiwatts (which were relatively quiet) and pedals - thank god drummers are loud!The fact is friend, guitars and their amplifiers have ALWAYS* been noisy Bs! The amps themselves were often not that well designed for low noise and as ' rock n roll' moved into ever more high gain, distorted sounds this got worse. But, noisy as a 100W amp was, once you hit the strings the headroom was SO immense that the "Signal to Noise Ratio" was in fact pretty good. The drummer had deafened everybody anyway!
ISO transformers? Do you mean balanced mains supplies? Probably not so bad when it is about 55V above earth but over here such gear constitutes a big hazard to service personnel who may not realized that even though a mains fuse has popped, one side it still at 115V ref earth.I have ISO transformers on my electrical feeds to my room - have for years - amps and just about everything are dead quiet - I used to use a similar system live and it work work very well - but I remember the days of my Hiwatts (which were relatively quiet) and pedals - thank god drummers are loud!
I use Isolation transformers and Balance Power for the incoming power - it is a silent system completely insulated from any external noise, glitches , appliances etc….and my amps respond according - some of my older amps run at less than 120 - my Hiwatts run and sound best at 105 volts - so I have a few stepdown devices - when the amps get the correct voltage they perform smooth as silk -ISO transformers? Do you mean balanced mains supplies?
I just have it in my Studio Room - I had a 80amp service wired just to my room - straight from the breaker box.That's interesting - virtually unheard of in the UK. Every house has their mains come in and then goes to the sockets and appliances - we don't use transformers in domestic properties.
If the noise changes as you move around, electromagnetic interference is the root problem. You have two choices, eliminate the interference or shield the guitar. Move the guitar around until you find where the interference is coming from and address that. When the noise get loud, that's your clue!"I can move my guitar around the basement and get more or less noise"
Yes, same here! Unfortunately, the exact position that the guitarist needs to be, due to filming, in is where the noise occurs. The guitar is a hollow body archtop, and it does have a humbucker. We're not using an amp, we're going direct into the mixer's Hi-Z input. The only thing that has worked to help (not eliminate) the hum, is the wire in the sock trick...
Yeah I guess we're stuck with the noise then, sucks!
Well, hang on! How bad is it? Post a clip* of guitar at -20 dBFS average oriented for minimum hum then damp the stings for say 20 seconds. If your noise floor is better than -70dBFS I would say you are doing pretty well. If significantly worse than neg 70 then you need to investigate noise gates and post tracking software.Yeah I guess we're stuck with the noise then, sucks!
In that case, record the track with the guitar in the "null" position then video the guy miming to the track. Unless there are legal/contractual reasons why that can't be done. Pretty standard practice in the film work? Post dubbing because the location is just too noisy or the sound is compromised in some other way.I don't have a clip to post, but I believe the noise is around -40 on the meter. I do use a noise gate, but it's only helpful when the guitar isn't being played. The guitar is usually an archtop hollow body, with Kent Armstrong high quality humbucker pickup. I know the noise is interference because if we move him around, face another direction, it goes away. Problem is it's a video studio, and he kind of needs to be where he is, and oriented in the direction that he is, that just happens to be where the noise comes in.
If you getting noise through your guitar which has Humbucking Pickups the problem is either 1. You guitar is wired funky and needs to be fixed 2. the Cable you are using is wonky and needs replaced - one or more of the video devices have a ground issue that needs to be addressed - I would also look at the video monitors and make sure they are grounded properly or get new properly shielded Monitor that don’t leak.I don't have a clip to post, but I believe the noise is around -40 on the meter. I do use a noise gate, but it's only helpful when the guitar isn't being played. The guitar is usually an archtop hollow body, with Kent Armstrong high quality humbucker pickup. I know the noise is interference because if we move him around, face another direction, it goes away. Problem is it's a video studio, and he kind of needs to be where he is, and oriented in the direction that he is, that just happens to be where the noise comes in.
There are two ways mains noise gets into the guitar. The primary cause is electro-MAGNETIC coupling. Your pickups become in effect the secondary of a huge AC transformer! There is little you can do about that. Mic transformers can be completely enclosed in "mu metal" which can effect 30dB+ of hum reduction but of course, a totally enclosed git pup would pickup FA! No, humbuckers are the answer there.
A lesser, secondary effect is electro-STATIC coupling and can be virtually eliminated by screening the pup cavity NOT forgetting the back of the scratchpalte.
*An MP3 clip at the best rate 320kHz is the most useful form for me (.wav would be better but we can't have that)
OK here's the MO.@ecc83 , I want to make an audio clip to post so you can hear it, but I didn't fully understand your instructions. If I record from the mixer to the computer with hands off the strings, and then hands on the strings, would that be sufficient?
