J
jenschristian
Hello
I have a problem with my AKG C5900 microphone.
When connected to my Yamaha power mixer the microphone will make a destinct humming when you touch the micropone "grill".
It will come and go with the touch.
That leads me to believe it is something with a ground-failure, but I can not find any bad connections.
Phantom power is on and I have tried and tested cable and mixer channel with a different microphone -no problems.
What should I look for when I have the microphone disassembled?
When the humming is not there and you are carefully NOT to touch the "grill" -then the microphone is working perfectly.
But if you slightly touch in the wrong place - the humming is back.
Let me know if you need further information!
I hope that someone has got the needed experience that I do not
Thanks
Jens Christian
Denmark
Thanks
Jens Christian
Denmark
