ACMP73 with Neumann TLM49
The last review I did of the ACMP pre's with the SM7 mic had a few people wondering if I was setting the gain stages wrong because I found distortion in both units when setting decent levels.
To confirm:
The gain knob (the one that goes up and down in increments) acts similar to a distortion knob.  The more you turn it up, the more distortion you'll get.  At a high setting it's very apparent.
The output knob, on the other hand, is a volume control and will not add distortion.
When I tested the ACMP73/84 with the SM7 I had to max the output and turn the gain up enough to the point that it distorted the mic in order to get an acceptable level.
 Your experience may vary but that is what I've come away with.
For the test with the TLM49 I made 4 different gain/output settings to test the ACMP73 at and also tested with other pre's.
Chain: Mid/quiet male pop vocal > TLM49 > Pre > Lynx Aurora AD/DA
Same cables used for each test.  The TLM49 has a presence rise that can lend to sibilance and a slow bass rolloff.
The top three were close.  The song would really determine which would be best:
#1.
Avalon M5: Clarity!  The most clean.  Tight.  Deep controlled bass.  Cuts through without unnecessary presence that the other pre's have.  The least sibilance problems.  Good vibe.
#2.
Pacifica with pad on: Mids gives it a nice vibe, fairly sibilant compared to the M5.  Bass not quite as nice as the M5 but it's right about there.
#3.
ACMP73, Gain 1 notch from -20 (in otherwords, set low), output maxed
(cleanest of the ACMP settings made):  Big, more full sounding than the M5 or Pacifica (with pad on the Pacifica).  Has nice a vibe.  Bass a little more loose than the M5 or Pacifica. More sibilant than the Pacifica.  Would require more EQ than the M5 or Pacifica in a mix.  Only other worry with ACMP here is that it's so big it wouldn't stack well in multiple vocal tracks.
#4.
Pacifica: somewhat scooped, bass is nice but not quite as good as the M5.  Better sibilance and T's than the ACMP73
#5.
ACMP73, Gain 3 notches from -20, output at 2 o'clock: Similar to the cleanest ACMP setting but sibilance becoming more apparent; T's become an issue.
#6.
UA160: Sibilance very apparent, lots of bass and highs, mids somewhat week, T's and Ch's apparent, very slight distortion.  Not particularly pleasant.
#7.
ACMP73, Gain 5 notches from -20, output at 9 o'clock: Too sibilant, distortion becoming audible like the UA610.
#8.
ACMP73, Gain at -80 (in otherwords maxed), output at near lowest level
(this was the dirtiest of the ACMP settings made): Distorted though not particually bad, nice bass though loose, does have a vibe, not quite as nice as Pacifica w/ pad in.  Heavy sibilance though.  Sounds like overloading.
Much different than with the SM7 test, the ACMP (set clean) came out towards the top beating pre's in the $800 range in this test.
My initial reaction to hearing it with the TLM49 was, "Whoa, this sounds big and full!"
For mics that don't require a lot of gain, the ACMP's can hang right in there with very good pre's.  However, I didn't test with the EQ engaged for this one.  Considering the pre itself sounds this good though, I feel pretty forgiving about any noise added by the EQ.
Major thumbs up to Chance on this one: thanks, man.
For the record, I'm not into praising gear for the sake of The Brotherhood of Man.  I know a lot of folks on the forums have a bit of a hard time saying anything negative about the Group Buy pre's and mics.  I'm personally not interested in brown nosing Chance or the gear I took part in purchasing.  When it sounds great I say so.  When it sounds like garbage I say so.  If Chance worked his ass off it's worth kudos
but it irrelevant to the gear itself.   Confusing the two is ...confusing
