dgatwood
is out. Leave a message.
Unless you're trying to get distortion for some reason or unless your sources are so hot that they clip at your DAW with the input gain at the bottom, you should generally leave the output gain all the way up and use the input gain to set the level.
If the input gain isn't fine-grained enough, you can set the input gain a little high and tone it down a little with the output gain; just remember that your lowest noise level occurs when you minimize the input gain level as much as possible without compromising the resulting level.
I also did what you said about the output gain (on both - 12 o'clock). There was never any intentional normalization, and I'm sure there was none on the .wav files -- to anyone who wants to hear the original samples that mshilarious is talking about, use the links in my previous post, but delete the "1" at the end of the filename before the extension.
(20+ years professionally full time) - and have been putting them up against my API's, Shadow Hills GAMA's, Biz and D&R's with a variety of mics and they are more than holding their own. Money aside, they are holding their own, and exceeding all of those listed pre's in various situations. If you want to add the price into the equation, they are unFREAKINGbelieveable.
