poopchute
Hey!
I have a question bout sync and TSR-8's. Actually three. So Ill number them.
1. I have experienced the dreaded anal drift. I want to know if what I want to do is possible with sync. I know you need to stripp channel 8 with some type of time code. But let's say I do that and fill up the other 7 tracks. Then I dump them into Pro-Tools. Now from what I have read it appears that everyone just dumps the result back to the exact spot on the tape that the originals came from. I dont want to do that. I would like to move to a fresh spot on the tape and dump it there but also be able to keep the computer and TSR-8 in sync. Is this possible? Or do I have to keep it in the exact same spot for the sync to work?
2. Since I have never tried to sync anything together, when everything is synced what happens? I mean if Im recording to the TSR-8 with the computer synced up will I see the same audio that Im recording appear in Protools as if Im recording it there without the TSR-8?
3. If I want to do midi drums with this setup is this even possible? Or should I just do the midi drums in PT and not even attempt them in Anal?
Thanks for any help in advance.
